Page 4 of 4
Re: Securing rudder when tied down outside
Posted: Sun May 12, 2019 2:22 am
by rnealon1
Finally got around to making this. Created a makeshift fid with a metal punch and tape. Seems to work great.
Posted: Sun May 12, 2019 2:11 pm
Success! LOL
Yes, the 170 is a challenge when it comes to securing the rudder. If you walk around the flight line you can usually find a 170 (or similar type) with damaged rudders and rudder-bellcranks where they've been beaten against the stops. Using the top of the rudder to slip a "pad" between the rudder counter-balance/horn and vertical stabilizer is another sure-fire method to KILL the rudder, because a wind gust will bend the rudder counterbalance.
Glad to see your Success! Congratulations!
Posted: Thu Feb 11, 2021 4:01 pm
by KFS1998
I came across this gem on Ebay. I wont be able to fit it until i buy the airplane but for now its safely stored in my treasure box.
Has anyone seen this before?
Posted: Thu Feb 11, 2021 4:21 pm
by hilltop170
I had a Cub with a stick control lock similar to that.
Posted: Thu Feb 11, 2021 4:23 pm
by KFS1998
This appears to go between the rudder bellcrank and the top portion of the tailwheel. We’ll see.
Posted: Thu Feb 11, 2021 6:03 pm
The series “6” PN leads me to believe this is for an L19/O1 BirdDog. Maybe slips over the stick and against the rudder pedals.
Posted: Thu Feb 11, 2021 6:58 pm
by n2582d
- 1966-75 C-188 AgWagon IPC Fig. 64-27A
p/n is 1600101-1
Now you just have to figure out how to convert the 170 from a control wheel to a stick. That would be a cool STC!
Posted: Thu Feb 11, 2021 10:42 pm
n2582d wrote:Screen Shot 2021-02-11 at 11.10.36 AM.png
p/n is 1600101-1
That’s an “8” series PN drawing which applies to the Agwagon.
Posted: Fri Feb 12, 2021 3:22 am
by TFA170
I'd buy it in a heartbeat! About the only improvement you could possibly make...other than a bigger engine.
Posted: Mon Feb 22, 2021 5:28 am
by reecewallace
I just made one and it works great. Local shoe repair store took the outline I got from this site and made one, $12
Thanks for the tips and outline!
Posted: Mon Feb 22, 2021 5:58 pm
by IA DPE
n2582d wrote:Now you just have to figure out how to convert the 170 from a control wheel to a stick. That would be a cool STC!
I find aircraft with Sticks much harder to enter/ egress and love the 170 for their ease of doing both.
Flying a Cub/ Super Cub/ Champ are fun but getting in/ out is gymnastics. I'm too old.
Posted: Mon Feb 22, 2021 6:07 pm
by 4583C
IA DPE wrote:n2582d wrote:Now you just have to figure out how to convert the 170 from a control wheel to a stick. That would be a cool STC!
Agreed!! I did my flight review in a Super Cub last spring and it convinced me of the wisdom you expressed.
Posted: Mon Mar 29, 2021 3:17 pm
by Karl Towle
I thought some may be interested in a solution I came up with. Maybe someone can improve upon it. Here's the picture:
Specs:
1) Locks both rudder and elevator, at their trailing edges, while also cradling the aft 10" of each surface at a rib.
2) Eliminates stresses on control system.
3) Cradles the rudder just above the position light, so will also work with tailBeacon equipped aircraft.
4) Lighter weight than PVC based designs.
5) Padding is cheap and easily replaced plumbing insulation available from most hardware/plumbing sources.
6) Positively held in place by dual, redundant bungee straps.
7) If one forgets to remove, the lack of tailwheel steering should make the oversight obvious to the pilot while attempting to taxi.
8] Can be disassembled and collapsed for storage (total weight: 3.5 lbs including bungee straps.)
This will NOT fit the 170 or 170A without design modification.
