Stall Warning Indicator Lamp
For those of you like one of our directors
who have been flying around with no indicator lamp in your stall warning..... the bulb/lamp is a G.E. 1816 and may be found at most automotive parts stores. (Your Cessna Dealers also carry them for about $2. (A substitute is G.E. 1893, but it may be slightly dimmer.)
- jlwild
Re: Stall Warning Indicator Lamp
Gosh George, I wonder who you are thinking about
And, I wonder who forgot that I have been looking for a bulb for the the last 2 years
Oh, well plane didn't stall so guess it can wait until the NAPA aircraft parts store opens.
Jim Wildharber, Kennesaw, GA
George
Was the Stall Indicator Lamp standard issue for the 170 panels. I have a 56 Model B and do not have one? Where on the B Models was the light situated?
Kevin
Kevin
Kevin,
My '53 model had the lamp in the middle of the stall warning horn, mounted under the left side control yoke. On the later models they put a blanking plate there, and moved the warning horn to the back of the glove box and attached it with a bracket, but I think they eliminated the stall warning lamp. That is not gospel, but I have flown with a friend in his '55 model and do not recall seeing a lamp. I put in a different panel in mine and took the lamp out of the warning horn, moved the horn under dash, and put the indicator lamp directly in front of the left side pilots view. First night landing I did with the new panel scared the bejesus out of me when the light came on, ( forgot I had put it there on the rebuild of the panel). Jon
B-model aircraft, SN 26996 and on did not have the indicator light (lamp.)
