Aircraft Data
Posted: Sun Feb 08, 2009 8:00 pm
What is the correct spark plug gap for Unison plugs in our C-O300 engines? Where would this data normally be found?
What are the various cable tension values for the different size control cables in our planes? Also, is this data readily available? Where?
Finally some questions about fuel lines/hoses. Is the fuel line from the gascolator (fuel strainer in parts catalogue)to the carburetor the only line in out engine compartment that really needs to be firesleeved?
In the 1956 C-170B parts catalogue (ipc), I don't find any reference to the fuel line from the fuel strainer to the carburetor--illustrated or listed on pages 104, 105 & 105A. In my C-172 ipc, there is a reference to a "fuel hose assy" and has two part numbers--S-1167-6-0210 w/ code U and part # S-1167-8-0210 code R. Don't find any explanation of what the difference in the two codes are. I need to get the proper length so I can order a new fuel line and have it firesleeved w/ fittings. There is most likely some minor difference in hose lengths between my C-172 and a '56 C-170B due to the difference in gascolater/fuel strainer locations (mine is more to the right hand side of the firewall). Also wondering if anyone knows a good source in the Dallas/Fort Worth area to have one of these hoses made.
