Spark Checker
Posted: Fri Jul 17, 2009 1:19 pm
by davevramp
I have a spark plug cleaner with a spark checker that does not work.
I would like to build a ckt to produce the spark. But I would like to have the voltage the same the mag out put voltage. Any one out built one of these before? Any do and don’ts?
Re: Spark Checker
Posted: Sat Jul 18, 2009 2:17 am
Which test device do you have? Do you know why it doesn't work? Do you have air-pressure connected? (Some older devices do not create a spark until a pressure-switch is activated. One purpose of checking is to determine the plug fires under compression and at altitude.)
Re: Spark Checker
Posted: Sun Jul 19, 2009 6:33 am
by Robert Harik
The best thing to do is to use the exsisting circuit in your plug cleaner. If you cant fix it, then copy the circuit and build another one. I have built several for different purposes( not for aicraft) and there are just to many variables. I have built a lead tester,magneto- coil -condenser tester and a mag timmer, and I built all by opening up the "real " ones and copying the circuits.
