Is it possible to modify the 170A's bell crank tension with a 170B bell crank. I understand that the 170B's bell crank is counter balanced thus requiring less tension.
Bill
Elevator Bell Crank
- lowNslow
I am not familiar enough with the 170A model to know for sure, but remember you would also have to replace the the horizontal stabilizer as well. I don't know if this is a simple modification, and I have not heard of anyone doing it.william halford wrote:If that is the case, can the B model elevator be installed on the A model with no major involment..
No the B model elevator has different hinges than the A and will not bolt up.
You would have to change the horizonal stabilizer and the elevator to a B. Apperantly this can be done as it was to mine. I also know of another A model with the B model stabilizer and elevator combo. Paperwork is another matter!
