control surface repair
Can anyone recommend someone to repair/straighten rudder & elevator. They're just a looking a little "collapsed". Thanks in advance........
Jim
Jim
control surfaces
Exactly right. Any hopes of a fix?gahorn wrote:Collapsed? Like someone has been polishing them too aggressively and maybe overheated and "dished" them.
Jim
control surface
I've heard of the dry ice trick. I've also been told it has no effect. Can the skins be removed, gently straightened, and reinstalled? Or is the metal too fatigued to remain "straightened"?N170BP wrote:A wheel barrow load of dry ice packed up next to the rudder
skins.....????
The answer/fix you probably don't want to hear, is to re-skin
them. Or find a decent replacement rudder (?)
Bela P. Havasreti
'54 C-170B N170BP
Jim
Never tried the dry ice thing myself.... but a friend
recently bought a '52 170 project that had hail damage.
The previous owner successfully removed most (if
not all) of the hail dings in the fuselage utilizing the
dry ice & dolly trick.
Having just completely rebuilt an early C-180 rudder,
I can suggest that if you are willing to drill the old
skins off, you might as well just replace them with new
skins. I spent enough time removing the corrosion from
the insides of the 180 rudder skins that it would have
made economic sense to just buy new skin stock, which
is available from more than one source (Jim Haydon - sp?
comes to mind).
Bela P. Havasreti
'54 C-170B N170BP
comes to mind).
Bela P. Havasreti
'54 C-170B N170BP
Per "Cessna Parts" category in T-A-P,
"Corrugated skin..........call Karl 360-757-1946" in Bow WA. Jim Hayton (in Sedro Wooley) priobably buys his skins there. Jim is more the guy to see for a complete airframe rebuild. He rebuilt Jan Liberty's 180 after a hangar at Harvey collapsed on it a few winters ago--it came out beautiful.
Bela,who bought the '52 project?
Thanks for the contact on the skins (Karl in Bow).
I've never done it, but the way it was explained
to me, you need access to both sides of the skins
to do the dry ice trick. You rub the ice on one
side and gently push the dented skin back out
with the dolly on the other side (slide the dolly
back & forth a bit). There's no doubt a little "art
form" thing to it, and if you're trying to repair
an aircraft with hail damage, I bet a guy could
get pretty good at it after dozens of attempts!
A buddy of mine I work with bought the '52 project
(his name is Tim Shaver, he lives at Crest). This
'52 sat in a pole-building/barn in Kent and in a
garage in the Bonney Lake area for many years
in a partially restored state.
Bela P. Havasreti
'54 C-170B N170BP
Bela P. Havasreti
'54 C-170B N170BP
If there was a photo I couldn't see it to get an idea of the "dishing" that was mentioned. I have had considerable sucess on many planes in straightening a dishing by inserting a very long slender screwdriver and twisting or pushing the handle to force the tip against the skin along the "V" while pulling it back out. Take it a little at a time. A small phillips type is best or you could do some grinding and make a tip that more precisely fits the groove. You need a quality tool that is hardened along its length so it won't bend. This has worked on rudders, elevaters, flaps, and ailerons for me with much succes. Sure makes them look better.
N92CP ("Clark's Plane")
1953 C-180
1953 C-180
Sounds like good (and cheap) advice. I'm going to call it Plan "A". Thanks.....Dave Clark wrote:If there was a photo I couldn't see it to get an idea of the "dishing" that was mentioned. I have had considerable sucess on many planes in straightening a dishing by inserting a very long slender screwdriver and twisting or pushing the handle to force the tip against the skin along the "V" while pulling it back out. Take it a little at a time. A small phillips type is best or you could do some grinding and make a tip that more precisely fits the groove. You need a quality tool that is hardened along its length so it won't bend. This has worked on rudders, elevaters, flaps, and ailerons for me with much succes. Sure makes them look better.
Jim
- wa4jr
I don't know if I would try this on my plane or not, but I have seen folks spray the expanding foam sealer inside their control surfaces. When the sealer expands...IF you spray in the correct amount...the control surface is brought out true and you no longer have the hollow oil canning sound. Needless to say, if you mess up and get too much sealer in the cavity, you end up with some really funny looking "bulges" in your skins...but then maybe you can compress them down to proper appearance with your hands as the stuff expands. Has anyone here done this???
- lowNslow
No, No, NO!! Don't do it! The foam will not only attract water, hold it, and cause corrosion,...but it will also change the balance of the controls from day to day depending upon the moisture. It will also eventually break down into powder due to vibration, and then you'll have a real mess on your hands trying to correct this major error. (Anyone you've seen do this should be warned about this, and placed into the looney bin.)wa4jr wrote:I don't know if I would try this on my plane or not, but I have seen folks spray the expanding foam sealer inside their control surfaces. When the sealer expands...IF you spray in the correct amount...the control surface is brought out true and you no longer have the hollow oil canning sound. Needless to say, if you mess up and get too much sealer in the cavity, you end up with some really funny looking "bulges" in your skins...but then maybe you can compress them down to proper appearance with your hands as the stuff expands. Has anyone here done this???
