I finely ( after two years ) installed my headliner. ( Aircraft Spruce, wool.) After completion and admiring my work I picked up all my tools and discovered my Rosen visors still needed to be reinstalled. What has anyone done about cutting the liner to allow the back leg of the mount that goes up the back side of the spar? How did you trim it out?
Inquiring minds must know.
Scott.....53B
Rosen sunvisors / headliner
Re: Rosen sunvisors / headliner
Throw away the Rosens..... and SQUINT!
(The crows-feet will make you look experienced!)
Maybe I didn't install mine correctly (?), but mine don't attach on the backside (aft) side of the spar. They attach on the front of the spar where the factory sunvisors originally attached. Keep in mind my plane is a '56 172 so depending on your model 170 there may be some differences. I am sure you will get some input from other members.
I don't know squat aobut Rosen sunvisors, so I can't help you there, but at the risk of hijacking the original intent of the thread, how did the installation of the headliner go? Pictures?
Well, I was going to really step out and try to post pictures to show what I did and my questions. But we are in the process of changing computers, Can't download pictures - find old ones - or half my files. Thank goodness we are well backed up. I'll see if my better half can get us back up and I'll try again.
Note to 170C. Mine mount to the bottom of the spar and the angle goes up the back side in order for the hinge point to be foreward, out of the way. I have pictures and will post as soon as I can.
Scott.....53B
Scott.....53B
I just put a set of Rosen visors in to see how they would fit, I didn't install the headliner yet so I can get some pictures posted tonight on how they are installed on a 52 B model
shotgun34 L-19 #884 70-71 Chi Lang
The way I'm doing mine is the visor arm comes off, make a small incision in the front side of the headliner and slip it over the bracket arm you will have to reenforce the slit in the fabric to keep it from fraying. It is a much easier job with the headliner off, but you should be able to get yours pulled back far enough to do the job. You could do the all most the same thing by slitting the headliner so the aft part of the bracket goes through, you wouldn't have to roll back the headliner but the reenforcement on the fabric would show. I had to turn the picture to crop it, the top of the picture is the right side of the aircraft and the right side is forward.
My situation = Trimming arround the vertical leg after cutting thru the headliner.
Scott.....53B
Scott.....53B
Use "finishing tape" available at sewing/fabric shops. It's a method of serging the edges with simple fabric tape and comes in many colors. You might make a slit in the fabric then apply the tape.
