New cylinders
New cylinders
I have a C-145 that has 2000hrs TT and 600 SMOH. The engine had 100 hrs. in the last 31 years and the cylinder walls are rusty and pitted. Does any one have any suggestions on what type or brand of cylinder is the best replacement?
shotgun34 L-19 #884 70-71 Chi Lang
Re: New cylinders
This is likely to turn into an opinion-fest like if you'd asked about which brand motor-oil.
Personally...if I were to order all new cylinders these days, I'd be inclined to go with new TCM steel.
Virtually all mfrs have suffered at one time or the other with difficulties, but TCM has seemed to solve theirs and others
are still ongoing. Just an opinion.
Re: New cylinders
What BL is pointing to is having your cylinders bored .15 over removing the rust and of course the rest overhauled as needed. This could be the cheapest fix and perhaps as good as new seeing how manufactures keep having trouble with new. I would strongly consider this if the cylinders were new at the overhaul with only 600 hours on them. If they have 2000 thousand hours that doesn't disqualify them for and they are probably good candidates for overhaul but the expected life would be less and that makes new cylinders a bit more attractive.
Re: New cylinders
deleted
53 170B
Re: New cylinders
Here's a Mar 99 article on cylinders: http://www.amtonline.com/publication/ar ... &pageNum=1Bruce Fenstermacher wrote:What BL is pointing to is having your cylinders bored .15 over removing the rust and of course the rest overhauled as needed. This could be the cheapest fix and perhaps as good as new seeing how manufactures keep having trouble with new. I would strongly consider this if the cylinders were new at the overhaul with only 600 hours on them. If they have 2000 thousand hours that doesn't disqualify them for and they are probably good candidates for overhaul but the expected life would be less and that makes new cylinders a bit more attractive.
Another alternative is good old "channel chrome" if your present cylinders are first-runs. I never had a problem with a good set of plain old channel chrome cylinders...and they don't rust. But I'd only do this on my engine if it were a mid-life engine and I was chroming my own cylinders which I knew their history, i.e., their total time in-service was known. The above article explains why.
J&J in Pleasanton, TX, and Sentry in Ft. Worth Sentry Aircraft Cylinders
My first choice:
J & J Air Parts
830-569-3891
jjairparts.com
My other first choice:
Sentry
2731 Ludelle St, Fort Worth, TX 76105
(817) 531-2729
Re: New cylinders
I've seen quite a few cylinders that appear rusted and pitted that are satisfactorily cleaned up by ball honing only. Pitting frequently looks deeper than it really is and it is sumwhat difficult to accurately measure the depth.
If a cylinder can be cleaned up with either type of honing, it is a lot less costly than grinding them out to fifteen over and having to get new pistons.
Re: New cylinders
Various folks at Grand Prairie Airport (GPM) tell me that Sentry Cylinders in Fort Worth are no longer in business. I called their phone number listed on the internet and got someone's residential phone so I don't believe they are still open. I replaced my worn cylinders with ECI steel ones back in '99 and have been satisfied with them for 800+ hours.
As an aside, my plane is now hangared at Cleburne, TX Municiple Airport (CPT) for any of you that might be passing this way.
Re: New cylinders
The previous owner flew the A/C for @ 15 hrs on the engine after it had been run an average of just a few minutes a month in 31 years. The compression was in the high 60ties when I bought it. I used a pint of Avblend for the 4 hr flight home, drained the oil which was fresh when we started but looked like tar when we dumped the oil, did a compression check and the front two were in the low forties. I had the cylinders bore scoped that's when we found the rust and pitting. I haven't had the jugs removed, thats for latter on in the restoration. When I get them off I'll see if they can be used again. Thanks for the suggestions.
