Best three mods
Re: delete
Aryana wrote:Titanium too!
Ohh, could get the matching titanium gear legs too.
Would look great with chrome lug nuts :lol:
Re: delete
Then you would need some fuzzy dice, curb feelers & a foxtail for each antenna :mrgreen:
Re: delete
bagarre wrote:I thought there was only hollow, solid and steel.
There are at least two versions of hollow. The "reinforced" hollow axle has a smaller bore (thicker wall) inboard of the threads.
swixtt
Re: delete
Post by swixtt »
That is good info... Need to examine mine!
Re: Best three mods
Those thicker aluminium hollow axles are not bullet proof. My aircraft has never been on snow skies and it's been on wheels all its life . However during a recent 100hrly the wheels were removed for servicing it was noted the right hand a xle had slight bend in it .The axle was removed from the leg and to my horror the axle had cracked right at the flange where the it bolts to the leg. The crack had opened up to about 15 thou . It was a good save BUT the log books state solid axles had been fitted. The left side of the aircraft had a solid axle fitted.
Re: Best three mods
Did you find any corrosion on the inside of the axle at the crack?
Re: Best three mods
No corrosion was found at all . For some reason this aircraft has had no corrosion issues at all.the only issues have been bird strikes and ham fisted pilots [except me. Eh eh eh LOL :lol: ]
Re: Best three mods
All hollow aluminum axles are subject to cracks and failures. Even the thicker ones, due to the machine-marks inside. The solid aluminum "ski" axles are preferred, and the hollow steel axles are even better.
