Struts in windshield area?
cowman57
Post by cowman57 »
Just curious. Why do I see braces/struts above the dash board/behind the windshield in some 170 videos? Is this a modification, and for what purpose?
edbooth
Re: Struts in windshiels area?
Post by edbooth »
This is a fuselage strengthening modification for aircraft that are used on floats and skies.
pdb
Re: Struts in windshield area?
Post by pdb »
Ed is right.
The struts are known as V-Braces and are used to stiffen up the fuselage in the cockpit area to deal with the added stress of rough field, floats, and ski operations.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
cowman57
Post by cowman57 »
Thanks for the answer. Is this modification precautionary, or is there slight inherent weakness in the 170 cabin design?
pdb
Post by pdb »
I don't think its precautionary or indicative of a design weakness, I think it just reflects a modification for extra heavy duty service.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
mit
Post by mit »
Everything has a weak spot somewhere and when that is strengthened you move it somewhere else. Although over all might be stronger. Another example on a Cessna, is p-ponk.
Tim
pdb
Post by pdb »
Just remember that the goal of aeronautical engineers is to make every part as weak as possible.
If planes were built like locomotives, they would never fly.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
The pounding of waves/water really stresses (downward) the engine and it's mount, which transfers to the firewall/cabin area/windshield. The V-Brace stiffens that area up to avoid cracks. (not something the ordinary 170 will suffer even tho' 60-plus years of operations.)
Blue4
Post by Blue4 »
V-braces are still available as a special order from F. Atlee Dodge. They require a field approval to be installed in a 170. There are other good forum threads on the topic.
Personally, I was surprised at how much a V-brace stiffened the fuselage solely from the evidence of eliminating the windshield squeak. The difference was amazing.
I run floats, skis, and bush gear (but seldom all at the same time). If my bird was an airport-to-airport flier, the V-brace would not be necessary.
-S
