aircraft primer
aircraft primer
I'm trying to remember the name of the super duper, can't be beat, best in the world, 100% better than anything else, aricraft primer that they use at Flightcraft in Kelowna. Can anyone help. Thanks in advance. Randolph
It's an epoxy polyamide that requires mixing with a catalyst and protective equipment/breathing apparatus to safely use. For small jobs, the shaker-cans of zinc chromate are still the next-best thing, IMHO.
- tshort
It is probably similar to AKZO 2 part epoxy chromate primer available from spruce.
I'm using it on parts for the RV-8 and it is bombproof. MEK won't remove it, and bucking bars, etc have a hard time scratching it. Very durable.
It is nasty stuff, though.
Thomas
Thomas
Thomas Short
1948 C170 N3949V
RV-8 wings in progress
Indianapolis (KUMP)
1948 C170 N3949V
Indianapolis (KUMP)
- n2582d
Epoxy Primer
For reference here are a couple of other epoxy primers to consider when repainting your 170.
The first is from WLS Coatings. P/N 200-6 is a 2-part yellow epoxy primer. Order their R3 reducer with this. Del-Air is using this on what appears to be an award-winning C-170A restoration. Ironically the metal exposed to the weather is bare aluminum while the protected interior metal is primed with this impossible to remove primer. Another customer is Robinson Helicopters. They use this primer on their rotor blades. WLS Coatings is at 13413 S. Broadway in Los Angeles. Ask for John at (310) 538-2155.
I see that Aircraft Spruce recently added PTI's line of paint products. They have an epoxy polyamide available. See http://www.aircraftspruce.com/catalog/c ... primer.php
- n2582d
Cessna Recommended Epoxy Primer
This video shows MIL-PRF-2337G or later to be the current spec for an epoxy primer in areas of non-fuel tank parts. That is a typo; it should be MIL-PRF-23377G or later. They use AkzoNobel 10P8-11 in non-fuel tank areas. Google the MIL-Spec number (without the "G") for cheaper alternatives.
Re: aircraft primer
This is the best primer for metal I have found, It ships Haz Mat free, it is water born, your equipment cleans up with soap and water, what's left over in your gun goes back into the can. (no wasted paint) This primer can be over coated by any paint system, Randolph, Emron or any other URA product can be used to top coat.
It is thinned to spray with water, dries in minutes and can not be stripped by any stripper I have found.
http://www.stewartsystems.aero/products ... ray-gallon
- minton
Re: aircraft primer
As I recall there are "Primers" and there are (Primers). The two serve totally different purposes.
1). Paint primer, for use to build up surfaces and provide a compatible surface for finish coats to adhere to.
2). A protective coat to prevent corrosion. (Not to be over coated)
The second was originally developed to contain a sacrificial compound that was given up instead of allowing corrosion to establish itself on the coated metal. These days that seems to have gone out the window and now provides a sealed coating that is impervious to moisture, corrosive liquids and other compounds without the sacrificial components. This came about from our friendly EPA folks attempting to regulate us out of business.
The old Chromate products were great! I think A/C Spruce might still offer that product but you must read the ingredients carefully as many don't contain Chromate anymore. Same caution with the "NEW" and improved MEK's. When you do find it use the normal safety breathing equipment.
