Part No. for generator gasket
Anybody have a part no. and/or a source for the gasket between the engine and the generator, not an alternator. I have a Delco model 1101890, 20 amp generator. I need a new gasket in order to reinstall. Any suggestions?
Bernie Steadman
N2356D
Bernie Steadman
N2356D
- 170C
Re: Part No. for generator gasket
Bernie, I am sure some of our members will come through with a part number for you. However, if you have access to some gasket material its a pretty simple/easy job to make your own gasket.
PN 652072.....aircraft spruce 877 477 7823N2356D wrote:Anybody have a part no. and/or a source for the gasket between the engine and the generator, not an alternator. I have a Delco model 1101890, 20 amp generator. I need a new gasket in order to reinstall. Any suggestions?
Bernie Steadman
N2356D
Warning...change the tach drive oil seal at the same time.pn 642714
Thanks George,
I got the gasket and oil seal and everything installed OK. I had my generator rebuilt by Modified Aircraft Accessories in Brooks, KY. Very reasonable and returned with yellow tag. Now if I can find the time to fly it would be great. Trying to find some AGS type fuses. Aircraft Spruce lists AGC fuses which are 1/32 smaller in diameter than the AGS. Any thoughts.
Bernie
Bernie
AGS fuses are available from Hill Aircraft, http:www.cessnaparts.com/
(How 'bout that?... genuine Cessna parts from a Cessna distributor! and at a reasonable price, too!)
- LBPilot82
Soooo, is the consensus to use a bit of permatex #2 on this gasket? I replaced mine and put it in dry as recommended by my mechanic so as to not make the next replacement too difficult. After less than an hour flight time she's leaking pretty good right at the bottom of the gasket. I scraped the accessory case with a razor blade which would certainly be a pain with any type of hard gasket sealer.
Thanks in advance
Thanks in advance
Richard Dach
49' A Model N9007A
SN 18762
49' A Model N9007A
SN 18762
- edbooth
Are you sure it is the gasket leaking and not the generator oil seal leaking and running down there ?LBPilot82 wrote:Soooo, is the consensus to use a bit of permatex #2 on this gasket? I replaced mine and put it in dry as recommended by my mechanic so as to not make the next replacement too difficult. After less than an hour flight time she's leaking pretty good right at the bottom of the gasket. I scraped the accessory case with a razor blade which would certainly be a pain with any type of hard gasket sealer.
Thanks in advance
^^ That was/is my problem. For the longest time, I thought it was the gasket but it ended up being the generator shaft seal.edbooth wrote:Are you sure it is the gasket leaking and not the generator oil seal leaking and running down there ?LBPilot82 wrote:Soooo, is the consensus to use a bit of permatex #2 on this gasket? I replaced mine and put it in dry as recommended by my mechanic so as to not make the next replacement too difficult. After less than an hour flight time she's leaking pretty good right at the bottom of the gasket. I scraped the accessory case with a razor blade which would certainly be a pain with any type of hard gasket sealer.
Thanks in advance
Not only the oil seal...but also replace the O-ring at the shaft/woodruff-key.
- canav8
Richard has a Jasco Alternator on his 170A. His gasket was leaking. He took it off and found the problem.
52' C-170B N2713D Ser #25255
- LBPilot82
Yep, new alternator installed just a few weeks ago so I'm certain the shaft seal is good. Upon removal of the new unit, I found I didn't quite scrape all the gasket material off around the bottom stud. New gasket should arrive tomorrow. Live and learn!canav8 wrote:Richard has a Jasco Alternator on his 170A. His gasket was leaking. He took it off and found the problem.
Richard Dach
49' A Model N9007A
SN 18762
49' A Model N9007A
SN 18762
