Battery Options
Battery Options
Post by 170C »
In February 2012 I purchased a Concorde RG-25XC. New ones are now $53.00 more than in 2012 :( Mine has seemed to lack the twisting power the last few times I have flown it and I don't want to find myself stranded. Wondering if my best option is to purchase another one or consider the Odyssey route :?: Is the field approval quagmire worth the hassle and would I be any better off in the end :?: Looks like Spruce has the best prices on batteries.
DaveF
Re: Battery Options
Post by DaveF »
I'd first put a charge on the battery, then do a full discharge capacity test to see what condition it's really in. Then an equalizing (constant current) charge, and test it again. Chances are you can get it up to 90%, and you're good to go for another couple of years. By then there might be a Li-ion battery approved. That's my plan, anyway.
flyboy122
Re: Battery Options
Post by flyboy122 »
Have you checked all the wiring? Made sure all the connections are clean and tight? I was bit disappointed with my new Odyssey until I tightened the stud on the solenoid that come loose. (Note I said stud, not connection. The stud had actually backed out of the solenoid.)
The 337 for the Odyssey was pretty straightforward. That being said I wouldn't bother unless you really needed the weight and/or space (like I did).
DEM
bagarre
Re: Battery Options
Post by bagarre »
How much of a weight difference is there between a Gill, Concord and an Odyssey?
Re: Battery Options
Post by 170C »
Concorde RG-25XC weight = 23.5 lbs 24 ah's
Gil RG-25S = 25.0 lbs 18 ah's
Odyssey PC 680 = 16 lbs (not sure this is comparable model) 16 ah's
bagarre
Re: Battery Options
Post by bagarre »
Thanks! 9 pounds can make a difference. specially if folks have a bigger motor up front and forward CG issues.
Re: Battery Options
Post by 170C »
Agreed David. In my case I am not necessarily concerned about weight. Cost and performance are my hot buttons :mrgreen:
Re: Battery Options
Frank, I hate to tell you this...but I'd suggest you FIRST have your battery properly charged and do a capacity-check....and if it checks out...., next check for proper GROUNDS such as battery to airframe and battery to engine, and battery to starter.... then suspect that lightweight starter you have. :wink:
Re: Battery Options
Did anyone other than me ever use Pep Boys garden tractor batteries tn their airplane? They used to cost about $20 and were the exact same size as a Gill 25 series and I used to just put a new one in every annual. They always seemed to work just fine.
DaveF
Re: Battery Options
Post by DaveF »
No batteries cost $20 anymore. The battery for my '88 Honda that used to cost $40 at Walmart is now $100.
Re: Battery Options
blueldr wrote:Did anyone other than me ever use Pep Boys garden tractor batteries tn their airplane? They used to cost about $20 and were the exact same size as a Gill 25 series and I used to just put a new one in every annual. They always seemed to work just fine.
Absolutely NOT!
I NEVER used Pep Boys garden tractor batteries because WalMart was $2 cheaper!
(This was in my 206 to ferry it to annual inspection, of course, where it was replaced with a Gill....and long before anyone here could hold me accountable.) :wink:
N2625U
Re: Battery Options
Post by N2625U »
Gotta love statute of limitations...
YPK170guy
Re: Battery Options
Post by YPK170guy »
I just installed an an atlee dodge battery box as my original box was full of holes. I used the recommended battery and this is fully approved, also installed a sky tech starter at the same time. I needed a new battery at the same time, his saved a few pounds and seemed like a logical upgrade.
http://www.fadodge.com/index.php?option ... &Itemid=53
Re: Battery Options
I just had to replace the Concorde RG-25 XC battery in -15D. It lasted 6 years and cost $275 to replace from Aero Performance in Ft Worth, who is owned by the same folks that own Spruce. The last Concorde RG-25XC I had also lasted 6 years. Looks like Concorde RG-25XC batteries last 6 years, at least in my airplane.
lowNslow
Re: Battery Options
Post by lowNslow »
Richard, curious if you use a battery charger/maintainer when your aircraft is not in use?
