C-145-2H Engine Overhaul
nippaero
Re: C-145-2H Engine Overhaul
Post by nippaero »
Yeah something doesn't add up. Great catch guys. I'll call them this week and get to the bottom of it. I was talking to the AI I'm working with and we were wondering if they replaced the 8 prop bolt bushings on the flange and had a typo on the parts list. That's the only other thing that has a quality of 8. I'll let you know what I find out. Merry Christmas!
1952 170B
N8180A s/n 25032
sfarringer
Post by sfarringer »
gahorn wrote:
sfarringer wrote:Looks to me like they have 8 extra 530863 bushings on that invoice...... 8O
Yep. There should only be Two for the complete assy.
<edit> Perhaps it's a typo (and price mistake due to the typo), maybe the secy meant 530868, plate, crankshaft damper counterweight pin. There are 8 of those.
I think George has your answer..........
Ragwing S/N 18073
nippaero
Post by nippaero »
Yes or likely that. Thanks!!
1952 170B
N8180A s/n 25032
daedaluscan
Post by daedaluscan »
I have baffle envy
Charlie
1956 170B C-GDRG #27019
nippaero
Post by nippaero »
I got in touch with Aircraft Specialties and they caught the mistake on the invoice. They are going to refund the difference. :D Thanks everyone for the help with that.
I received my accessory case and oil sump today from DivCo. Still waiting on the case which is on the UPS truck.
You can see here a little bit of corrosion on the bottom of the oil sump.
1952 170B
N8180A s/n 25032
nippaero
Post by nippaero »
I did some cleaning and polishing on the exhaust parts today. A little buffing and polishing and they are looking pretty good.
Before and after.
1952 170B
N8180A s/n 25032
nippaero
Post by nippaero »
I used oven cleaner to get the grime off of the covers. It worked pretty good. The pipes and clamps I cleaned with oven cleaner and then bead blasted them. That is why they have a dull finish. Then I polished them out on a buffing wheel. I did not bead blast the covers. Nice thing about stainless is it buffs out like a mirror (usually).
1952 170B
N8180A s/n 25032
nippaero
Post by nippaero »
I received the replacement case today. It took a little extra time to get here because of the holidays. Everything looks great and it arrive with my original data plate and 8130 papers. I hope to get going on the case prep/cleanup tomorrow and then get some paint going on the engine parts. I am only missing a few items to put it back together and they should be here this week. We ordered all new hardware for the engine as well.
1952 170B
N8180A s/n 25032
nippaero
Post by nippaero »
I agree. We have some templates made out of cardboard for the cylinder and accessory holes. I guess aluminum would last longer.
Here is a picture of my O320 that was painted Lycoming gray. The alodined case along with the new hardware really make it look good.
1952 170B
N8180A s/n 25032
The FAA
Post by The FAA »
Aryana wrote:Oh boy, this is gonna be fun to watch. Beautiful work.
I'm not sure if you already mentioned this, but what shade of silver/gray are you planning on using for the Conti?
Yeah, tell us!
Federal Aviation Administration | Classic Certified Aircraft Compliance Division
6425 Denning Ave
Oklahoma City, OK 73169
"We're from the FAA, and we're here to help"
johneeb
Post by johneeb »
If you can make a Lycoming look this good your Continental should look fantastic!!
nippaero wrote: Image
nippaero
Post by nippaero »
Well, the color is Continental Gold but I know that doesn't mean much since I've seen several shades of it.
Here are the last two motors we did before mine to give you an idea of the color. Linda will be painting mine the same color today or tomorrow. The cylinders will be black Millennium's.
1952 170B
N8180A s/n 25032
gfeher
Post by gfeher »
Your not! I really appreciate them as well. I'm also envious if his arrangement with his experienced engine overhauler friend. I'd love to find someone like that in my neck of the woods to help him out and learn from.
Gene Feher
Argyle (1C3), NY
nippaero
Post by nippaero »
Here is the color of paint we are using on my motor.
1952 170B
N8180A s/n 25032
Post by 170C »
I think that Super Eagle would look good on my 172TD :!: It would be surprising what 85+ more horses & a cs prop would do for Ole Pokey :mrgreen:
