Hello All,
I have a rag wing 170. I'm currently having the engine (c-145/o-330) rebuilt. I also decided now would be a good time to have the engine mount gone through at Aerospace Welding in Minneapolis. Anyway, they called today and asked if I could measure the distance from center to center of the upper engine mount holes on the airframe? The technician went to secure the mount to my box I fabricated for the shipment and it was over an inch off. So, he asked if I could measure the holes to see where the error lay. Problem is, I live in the DFW area and my airplane is currently in a hangar 6 hours away. Does anyone have any experience with differences between various models of C170 models in regard to the engines and mounts?
Thanks, Cory
Motor mount help??
Re: Motor mount help??
Engine mounts, if not entirely, are all the same when it comes to that measurement. In other word they are all interchangeable between models.
- n2582d
36.25" on center between the two top engine mount holes on my 1952 170B firewall.
Thank you both for the info.
- rupertjl
I have the original cessna prints for the engine mount, the top mount dimension shows 18 5/32" from the centerline of the drawing and 13 13/16" for the bottom mounts from centerline.
1950 170A: N9191A s/n 19366
I measured mine on the floor and it is showing 36 5/8". Perhaps it sprung apart when we removed it. I can measure my holes tomorrow when I'm at the hanger.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
