Simple part I don't know proper name.
Would someone knowledgeable help me locate the part in IPC Sept 1, 1956 edition? Page and fig. number?
Two (2) simple fuselage "skin" parts, located at tail of fuselage dorsal side. Adjacent to vertical fin.
I want to use the term "fillet" but suspect that is wrong terminology.
Parts held in place by three screws - Has rubber X200 trim moulding on edge.
Shaped like long skinny pizza slice.
I have poured over the IPC numerous times.
Remain puzzled.
Locate fuselage Parts in IPC
- MoonlightVFR
gradyb, '54 B N2890C
Re: Locate fuselage Parts in IPC
Page 2 Figure 1 #8
On page 3
-8 0530009 Fairing - Empennage LH
0530009-1 Fairing - Empennage RH
On page 3
Do you need those? I have two fairly beat up ones that I'm about to duplicate.
I could send you the old ones to template or use (hail damaged)
Bruce... Have you started drankin'...??
- MoonlightVFR
Thank you Bruce
There it was on page 2.
I am thumbing the entire IPC .
pouring over it was just an idiom expression.
If I was pouring anything it was unsweetened tea.
- DaveF
Pour away with whatever beverage you like. But pore over your options before choosing!
