It was a little nerve-racking flying a new engine AND a plane that was completely re-assembled but it was non eventful.
The only squak we had was the generator. It is a brand new OH Falcon 20Amp. The first part of the flight the system was charging fine. About half way through the flight I noticed the generator did not appear to be charging. Battery voltage showed 12.7v with all the systems on.
When we removed the cowl for inspection we noticed this red waxy stiff all over the firewall. It was coming from the generator. It must have got hot and melted the internal insulation material. We removed the generator and had it tested by a local shop and it is working fine. Since I had to remove the generator, I decided to dump the oil and have a look at the screens. The fine screen had some fiber like material. Small black strands. I have never seen that before. We will keep a close eye on that.
I am looking fore some advice from the collective here. Could the regulator not be working causing the generator to over charge and get hot? Wouldn't the volt meter show a higher charge if that was the case? The regulator is the original unit. I plan on re-reading the generator troubleshooting in the 170 electrical manual again this evening.
Here's a couple pictures.
