0-360 c/s conversion question
Could someone with this conversion and with a constant speed tell me how the prop governor cable is installed i.e. how and where is it supported. does it have a bracket attached to the governor or is the bracket attached to the sump. Thks in advance
I don't have it, but I've seen two versions that had the cable attached via clamps to the oil sump bolts.
Dave Clark
Post by Dave Clark »
On the Avcon the bracket is attached to two of the mounting studs at the base for the governor and another leg going to one of the bolts higher on the governor itself.
The bracket for the throttle attaches to two of the carb bolts for the airbox and another to the sump pretty far aft, maybe the second or third side bolt from the rear.
N92CP ("Clark's Plane")
1953 C-180
