Well, here is my first of what may be many posts asking for a little help. I found this issue yesterday on my 170A where the cabin heat flange where the scat tube attached was corroded and damaged. We don't need cabin heat yet with our 90 degree days
Is the easiest repair to replace the whole piece that is riveted to the firewall, or can you cut off the damaged portion and rivet on a new flange to the current piece? Any suggestions on where to get a replacement part?
I'm not sure why the picture is upside down...
Doug, Gary has made a good suggestion for your repair. Your own will also work.
The A-model is not known for great cabin heat tho’. Since you’re waaay up NAWTH! ... you might want to look into wearing warm clothes as that heater is mostly famous for warming your left foot. (The later ‘53 models introduced much better cabin heat/ventilation and Richard Pulley (hilltop170) has posted articles here in the forums describing how he converted his A model to B model heat.)
