Cessna 170b windshield lower inner strip
seatothepants
Post by seatothepants »
Hello, all.
Im looking for part # 0510000-22, the inner lower windshield retainer for my restoration, mine is looking a little corroded and Im at a point where it would be "easy" to replace. Any thoughts on where I should look? I thought I would start with this group. Thanks in advance.
ghostflyer
Re: Cessna 170b windshield lower inner strip
Post by ghostflyer »
If you go to cessna or their distributor the cost of a new part will make your eyes water and maybe you will stop breathing. If you obtain one from the recyclers it could be butchered on removal or corroded also. Early Cessna 172,s have the same part. We have replaced 2 of these in our shop over the years and found making one in house far better. Originally it took 2 goes to come up with the acceptable part. I would be talking to a real good sheet metal guy. Maybe the corroded area could be cut out and a patch be inserted. To replace that part is a big job and alignment has to be done correctly .
When you finally get around to doing this I suggest you avoid the common attempts to seal up that area using ProSeal or other “pookie”. The windshield should “float” within it’s framework. Felt is the material to be used. It will “wick away” moisture and allow the area to dry-out without contributing to trapped moisture, corrosion, and cracking of a new windshield that was held too tightly.
