I'm having trouble hooking up my ailerons cables. Everything is hooked up and thought to be good, but then we tested and found that we can turn ailerons independent of each other by holding both yolks and turn one while holding the other yolk. Seems to be something wrong with our hook up of the item 3 figure 33 bar assembly.
Has anyone had that happen during riging up new cables?
Aileron Bar Assembly independent aileron movement
Re: Aileron Bar Assembly independent aileron movement
Careful! Don’t break those egg yolks.
Sounds as if your yoke universals/sprockets may not be correctly bolted/connected?
- gobrien
Not the best photography ever, but I took these before pulling mine apart last week:
https://yupon.com/owncloud/index.php/s/Z1T0kI6mQ25x7cS
1948 170 (N4180V) now EI-AEN SN:18513 - Dublin, Ireland
https://www.taildragger.eu/
- n2582d
Steve,
Sounds like you need to get an A&P to give you a hand. I suspect a missing bolt #8 or #12 or the universal joint, #14, has a sheared pin.
Thanks everyone got it fixed. Universal and sprocket, cleaned and links lined correctly. Again thanks for the advice..
