8 day clock
- rickyricky2
8 day clock
Hi All
My 8 day clock can not be wound.
Anybody know where to have it repaired?
I see online I can get a used one for about 100 dollars, but I don't know how worn it would be.
Thommen on the face.
Wakmann Watch Co on the rear case.
Dick Bryant
N2704C
Dick Bryant
N2704C
Re: 8 day clock
Check with these people as they do old antique and aircraft instruments.
http://www.keystoneinstruments.com/
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
- Kyle Wolfe
Re: 8 day clock
Kyle
54 B N1932C
57 BMW Isetta
54 B N1932C
57 BMW Isetta
Re: 8 day clock
The most common problem is overwinding. Will it run for a little while when you tap on it? If so, keep tapping on it to make it run and don't wind it.
- sfarringer
Re: 8 day clock
Here is another place:
https://historicaviationsupply.com/
They repaired my Thommen clock, back in 2013.
Ragwing S/N 18073
Re: 8 day clock
My old original wind-up clock in the 170 would only work when the engine was running. I would set it as part of the run-up and it would keep good time the entire flight. It would stop sometime after shut down. I never had to wind it very often. I guess there was enough internal drag it needed the engine vibration to keep running.
Re: 8 day clock
Historic answered my inquiry... They are not accepting new work until after the new year.
Re: 8 day clock
My understanding is that most of these are basically pocket-watch movements. If you have a good independent watchmaker in your area, you might try him.
Re: 8 day clock
I have had instruments repaired by Century Instrument in Wichita. http://www.centuryinstruments.net. An 8-Day clock is $355 outright, $250 Exchange, $180 to repair yours, Core Charge is $105.
When Dad filled out the panel in the 170 back in about 1952, he got his instruments at Century.
Bruce
1950 170A N5559C
1950 170A N5559C
