Does anyone have one of these Switch Limit Clips (PN 0411889) or know where I can get one? I'm adding a switch to my piano keys for strobe lights and would like the key to have the limit like the rest of them. I haven't had any luck finding one online.
Need Switch Limit Clip
- dstates
- n3833v
Re: Need Switch Limit Clip
Do you want the part that is fastened by the switch mounting nut? The "J" shaped piece.
If so, let me know and I will send you one.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
- dstates
n3833v wrote:Do you want the part that is fastened by the switch mounting nut? The "J" shaped piece.
Thanks, John. I sent you a PM.
As an alternative to adding a switch-stop on the strobe switch, if you have a rotating beacon or strobe replacing the beacon, you could consider adding a 3-position switch with the beacon-only position up and strobe and beacon position down, with off in the center.
Then, you could leave the switch up so the beacon-only will indicate to others you are ready to start up or that you left the master switch on after shutdown.
- dstates
Richard,hilltop170 wrote:As an alternative to adding a switch-stop on the strobe switch, if you have a rotating beacon or strobe replacing the beacon, you could consider adding a 3-position switch with the beacon-only position up and strobe and beacon position down, with off in the center.
That would work too. I don't currently have a beacon or strobes so I think I'll just add a switch for the strobes.
You could always go ahead and install a 3-way switch now in case you ever wanted a separate switch position for a beacon/single strobe. Down for strobes on and nothing in the up position. It's easy to see if you do position it up but nothing will happen.
I had Del Lehman wire my landing lights in the up position and taxi lights in the down position on the same switch, off in the center. I needed another switch position when the Pulse-Light was added.
- dstates
I agree and will be using a three position switch (all of them are three positions switches), but at this time I plan on a separate strobes switch.
