Found mine...hopefully...
Re: Found mine...hopefully...
If you think you want that airplane, then exchange “Letters of Intent” expressing you will make an “earnest money deposit” in return for a “first right of refusal” after an inspection by a mutually agreeable inspector, within XX-number of days, if the inspection does not occur within XX days or the airplane is found unairworthy, then the deposit is refunded.
- IP076
Thank you. That is taken care of. Where the hiccup is if the inspection doesn’t go well, and we’re not going to execute the sale, the airplane is now 300 miles from home. I would have no problem covering expenses and returning the airplane, the real potential issue is if an airworthiness issue was found that prevented flying the airplane home.
So, the real question at hand, anyone have a recommendation for a shop or mechanic to do a pre-purchase inspection in the Havre or Great Falls, Montana area?
Thank you.
Thank you.
IP076 wrote:Thank you. That is taken care of. Where the hiccup is if the inspection doesn’t go well, and we’re not going to execute the sale, the airplane is now 300 miles from home. I would have no problem covering expenses and returning the airplane, the real potential issue is if an airworthiness issue was found that prevented flying the airplane home.
Thank you.
That’s not a problem in MY book!
If the seller is claiming it’s airworthy.... and it’s found to be NOT airworthy.... getting the airplane either airworthy OR back home should be the SELLERS problem.
- IP076
I don’t necessarily disagree.
But it is what it is, and it’s a concern in this transaction. Again, I highly doubt there’s nefarious intent, just an old soul mentality and concern.
Since the last time I checked reasonable 170s aren’t growing on trees, I’d like to try and keep the deal together. What I’m looking for is a mechanic or shop who can do a pre-purchase inspection and at least check the big ticket items to give me a little peace of mind.
So...anyone have a suggestion for a shop in the Havre or Great Falls, Montana area?
- Kevin Pearce
I can highly recommend a shop and IA in Kalispell MT.
My 170B was maintained and inspected by Reed Lamb at Kalispell Airport.
Reed de-rigged, packed and shipped my 170B, and took so much care and created such good assembly instructions.
If you can get Reed to do a annual / pre-buy you will be in very good hands.
4426 Highway 2 East
Kalispell, MT 59901
USA
406-756-5829
You can tell him that Kevin Pearce recommended him.
I hope this helps.
Kevin
4426 Highway 2 East
Kalispell, MT 59901
USA
406-756-5829
I hope this helps.
Kevin
- IP076
Thank you Kevin! I'll see what I can work out. Still a little bit of distance, but I'll see what I can work out. Thanks for the info.Kevin Pearce wrote:I can highly recommend a shop and IA in Kalispell MT.
4426 Highway 2 East
Kalispell, MT 59901
USA
406-756-5829
I hope this helps.
Kevin
- counsellj
Great to have another 170 in Washington. Welcome
- Joe Moilanen
Yes it would be!!counsellj wrote:Great to have another 170 in Washington. Welcome
Joe
4518C
Yes definitely! Especially on the eastside.counsellj wrote:Great to have another 170 in Washington. Welcome
1950 Cessna 170A model
