I have a 1951 C-170A s/n 20216 equipped with the C-145 engine. I am coming up on engine overhaul time and would like to ask the membership for any thoughts on replacing one of the mags (Slick 6364s) with one of the certified electronic replacements vs standard mag replacement?
Electronic magneto replacement
- sreeves
Stephen Reeves
Palm Harbor, Florida
Cessna 170A, N1773D, S/N 20216
- sreeves
Re: Electronic magneto replacement
I guess the silence tells me all I need to know?
Stephen Reeves
I recently had two Bendix mag overhauled ($2100) Oct 2019 they seem to be going strong again.
Before there was quite a bit of mag drop. I heard the new ones either work or not no warning.
But add a little more power. It’s up to you . OOW
There are old pilots & There are bold pilots, But there are no old bold pilots !!!
2010 Team Tandem Airbike N700XX
1953 Cessna 170-B N3401C
First plane Cessna 175A N7000E
There are presently two systems (AFAIK) that are being made available to certified aircraft owners. Only one of them actually claims to increase power, which may or may not be of actual use. They are not cheap. Here’s an article from Aviation Consumer that may shed some light on the subject:
https://www.aviationconsumer.com/uncate ... ance-free/
Thanks for the link, I’m restoring a C-150 and considering using then on it, I have a ways to go before I’m ready.
