Cessna 170B 1953.
I see small holes in the leading edge of the horizontal stab, I think there is 4 of them.
What are those small holes made for?
If installing an abrasion boot , they will all be covered.
Small holes on the leading edge of horizontal
- n2582d
Re: Small holes on the leading edge of horizontal
I don't know for certain but my best guess is that they are holes used for alignment pins in the factory's jigs when the parts are formed.
Yep, that’s what I’ve always been told. Former Historian (and aircraft engineering consultant) also said this was their purpose.n2582d wrote:I don't know for certain but my best guess is that they are holes used for alignment pins in the factory's jigs when the parts are formed.
Hmmm… I have always ASSuMEd they were vent holes to reduce condensation inside the surface, but the tooling hole idea makes a LOT more sense.
- n3833v
I thought some were used to mount longwire antennas.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
I agree with Miles, I was told to keep them clear of dirt and bugs.
No, ... long wire antennas connected to a ceramic-tower on top of the boot-cowl in front of the windshield, travelled up to the linen/resin post above the windshield, then went aft and passed-through a fitting on top of the rudder and trailed-behind.n3833v wrote:I thought some were used to mount longwire antennas.
HOwever, an ADF “sense” antenna was attached to a “key-slot” cut in the leading edge of the vertical stabilizer.
The small holes were not drain holes or anything other than spigots for assembly-line alignment jigs. (Again, per Cleo and I believe I’ve heard Del Lehman say the same.)
