John, you have to mount the Nulites between the instrument and the panel. Which brings me to something I forgot to mention the first time: You will need some longer brass screws and if you are using instrument mounting nuts, they will either have to be longer or you'll just have to "nip" off the turned out ends, to accomodate the 3/16" difference in thickness (or if you are using ordinary nuts, you can use strips of masking tape to hold the nulites to the instruments to facilitate the installation).
The spacing between the panel and the overlay will remain the same, but your instruments will now sit 3/16" farther back, which means that the rings will sit that same distance farther from the bezel, which means that on the eyebrow panel like on my '52, the whole left side of the tach cannot be seen without moving your head to the copilot's area... Even in daylite. It is difficult to explain, but if you want to try and visualize it before you spend the $$, remove the tach and re-install it at a 3/16" distance by using spacers or wahers betweeen the face of it and the panel; then, position your seat in the flying position and see the effect of the ring on the placement change.
I still think it was worth the mod for me, yes, it is true that my panel is not "original" as in the way it came out of the factory, but it is "original" as in, you won't see an other one like it. But the most important is that the lighting is fantastic and even if I always carry 4 flashlites including headset mounted units, it makes flying at nite more pleasant. If you wannt to see pictures of my panel, Email me (
jdhoude@sympatico.ca) and I'll send you JPegs. Good luck, JD
