Anyone know what the 170b airbox is made from? 4130? Mild steel? Galvanized? Mix dependent on component?
Appreciate it if someone has experience on this. Need to do a small weld repair.
Thanks!
Airbox repairs-What alloy?
- schnepel
Re: Airbox repairs-What alloy?
Mild steel, I don’t see a need for 4130 on the box. Galvanized metal would produce dangerous gas in the event of a fire. I’ve brazed on box components (lower heat that helps minimize warping the metal) in the past with good results.
Thanks for the feedback. Also the first post in almost 10 years? Welcome.
- schnepel
Vertical wrote:Thanks for the feedback. Also the first post in almost 10 years? Welcome.
