Is there a separate nut that the rear seat bolts go into or is there a nut plate or some type of welded nut that the bolts screw in to?
I wasn't sure if I need to pull inspection plate to catch any loose nuts for rear seat removal.
Can someone explain what's under there?
Rear Seat Bolt Question
- Richgj3
Re: Rear Seat Bolt Question
They are nut plates. Be careful not to strip them. Look difficult to replace!
- DaveF
Here you go!
viewtopic.php?p=67208
