The time has come to start my conversion.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
http://www.fullenfamily.com/N9153B.htm
All of the Bolen / Bush conversions that I have seen also use a long plate to span the last two fuselage bulkheads. I would like to see what yours looks like if you can send me a picture.170C wrote:Your photos sure look neat. Keep them coming. Wow, that tailwheel bracket is long! Mine (Bolen Conversion) looks long compared to a 170's, but yours appears to be 50% longer. Does yours add a stringer in the aft part of the plane? Are you going to use 170 gear or something else?
mod cessna wrote:53b. Looks good so far. I am doing the same thing right now with the same STC. I have yet to tackle the tail wheel but i am almost done with the main gear install. Here are a few pics of it so far. I would really like to do something different with the tail wheel install but what is approved is approved. Any help i can give ya just let me know. http://pg.photos.yahoo.com/ph/mattvoit/ ... EB.6eYqUIz
mod cessna wrote:Yes I did notice the shape of your rear attachment. It looks good. It sounds like you had to go through a lot to make it work.
Here are a few things to consider on the main gear.
1. I replaced the fwd side and bottom skins because of previous damage, but the part number 0513006-23 fwd bulkhead angle can only be installed by removing the fwd bulkhead that it is riveted to or by removing one of the fuselage side skins. I know at least on of the conversion STC's have you cut a 2" hole in the side of the fuselage to slide it through. Removing and re-installing the side skin is only a few hour job at the most so I would do that.
2. The STC does not say to change the top gear box cover skin (#40 fig 21 170b IPC) Big mistake! Fist off it has to be lengthened to pick up PN 0513006-23. The 172 skin stops at the bulkhead, the 170 is riveted to the angle only. Also the 172 skin is very thin, I think it is .032 the 170 skin is much thicker.
3. Fwd floor panels (where your feat go) have issues. Be prepared for some fitting issues. I made new ones.
4. P-ponk gear attachments. Work great, very nice product.
Those were the big issues. I will let you know if anything else big comes up. I cant wait to fly this airplane.
My bulkhead angle all ready had a few holes in it so it ended up being flush with the top of the bulkhead. As it should be. The floor pans can be made to fit by trimming about an inch off the end so it stop where the bulkhead and angle meat. Then putting a bend where it comes up to the angle. Ooops now the holes on the tunnel and side panel do not match up. So i just made new ones. Custom fit.I knew that I would have to take one of the side panels loose to get that angle in. I also wondered how I would get that angle tight up against the floor pans where your feet go since they have such an angle to them where they meet the bulkhead.
No they go under ok. The problem with the steel reinforcements is they are drilled. The drilled holes just do not match up well at all. It just takes some careful placement.Is there an issue getting those steel reinforcements under the engine mount carry through straps where they overlap the bulkhead flange? I would hate to have to pull the engine off just for that.
No. The holes on the outboard attachment are a size smaller(in the bulkhead). It took lots of reaming drilling filling to get the holes to the proper size. You should have an interference fit with the bolts.Finally, (for today) do the bolts fit through the holes as they are or will they need to be reamed to fit?
