I currently fly a little PA-22, but just bought a '56 172 tailwheel that needs to be put together after 10 years of disassembly. It looks complete and came with a shiny 0 SMOH Avcon O-360 conversion, but no prop, so I'll be shopping for one of those...
I've already been searching through the old threads and have picked up tons of useful info on some of the things I'm dealing with (float kit, cargo door, etc). Man, that gahorn can type!
A couple of questions I needed some advice/input on as I get going on this project:
1. On the engine mounts at the firewall; Do I go with rubber or aluminum bushings? The plane came with new-looking rubbers in the mount holes that I think came with the Avcon conversion, but my mechanic thought aluminum would be better, and the drawings look like aluminum... anyone with the Avcon setup have an opinion?
2. Float kit; Configure for 170 floats or 172 floats? I could go either way, but is there more availability or issues with one type over the other?
3. 175 tanks; Seems like the consensus is the stock 172 tanks are a bit short-legged for the 180hp. Are the 175 tanks impossible to find, or should I look to other options?
Any input would be great, and if you're in the area, PM me. I'm looking for all the help I can find... moose season is almost here!
J.R.
