Max Oil Pressure
Max Oil Pressure
In a recent thread, Bruce stated:
N9149A wrote:...Also I just thought about oil pressure. Mine is running about 60psi. Just looked in the TCDS for the C-145 and it's the range is 30-40psi. Normally I'd not worry about this but I guess I'll make an adjustment there... 8O
I responded about a conversation I'd had with the TCM representative who anecdotally stated that oil pressure up to 60 psi is OK in the O-300 series engines. Someone else then mentioned that it'd have been nice if TCM had put that in writing. (Certainly a good comment.)
Today I was reading thru TCM Form X30015 "Operators Manual", an FAA Approved document, and read on page 1, Specifications, that "Oil Pressure (cruising) (lbs/sq. in.)" is 30-60.
Just wanted to mention that now we've seen it in print from the mfr.
(This document can also be seen on the Member's Only Page of this website.)
lowNslow
Post by lowNslow »
This document still list 30-45psi for my C145. :(
What document are you referring to, Karl? I'm referring to the document displayed at the Members Page. (I'm pretty certain it's the same one displayed on your members page as well.) :lol:
N2255D
Post by N2255D »
Under Specifications C-125 shows 30-40, C-145 30-45, and for the O-300 it's 30-60.
Walt Weaver
Spencer Airport (NC35)
lowNslow
Post by lowNslow »
N2255D wrote:Under Specifications C-125 shows 30-40, C-145 30-45, and for the O-300 it's 30-60.
Took the words right out of my mouth. :lol:
When I'm talking max oil pressure I have a 0-300A installed. Otherwise it's a C-145. :wink:
lowNslow
Post by lowNslow »
Bruce wrote:When I'm talking max oil pressure I have a 0-300A installed. Otherwise it's a C-145. :wink:
OK, then that's my story and I'm sticken to it. If "they" have any questions I'll send them to you. :wink:
Mark
Post by Mark »
Thank you for this
my 'new' engine is running at almost 50 psi at cruise and I was getting concerned
it is the smoothest engine I have ever flown behind
but this info gives me a bit more peace of mind about it
