Actually, there are quite a few people who seem to have a problem with replacing Duracells on an annual basis. I'm amazed but it's true. It's possible they don't know about the issue, or simply disagree, or ???? but... I just wanted folks to know what more than one FSDO Inspector says about it. (I simply put them in my household flashlights and use them in that capacity, and operate my ELT with new Duracells each year. Depending on where I buy the new Duracells, it's actually possible to install batteries in the ELT that have dates which imply they are "lesser" than the ones '"ve removed.)swanstedt wrote:George,
Do your comments regarding annual battery replacement also pertain to proprietary, specialized, $50+ ELT batteries that have a 5-year life/replacement, or $40+ 2-year life/replacement batteries? I don't think anyone would have a problem of throwing in a new set of Duracells on annual...but not all ELTs take Duracells.
I understand your point Bruce, but it's contrary to what I've been told by the FSDO. For example, in the case of the ACK ELT E-01 already discussed, the ELT mfr's manual requires they be replaced upon reaching the date stamped on the battery.... BUT... that date does not guarantee that 50% of the Duracell battery's capacity is still valid. This implies that EITHER the date OR the 50% rule can limit the life of the battery. Duracell will not offer any guarantees their batteries will retain 50% capacity after installation. NOW what is the limit? (Unless the battery can be tested... once installed, it's shelf-life is no longer applicable. The date on the battery is a SHELF life...not an INSTALLED life.)N9149A wrote:George I must disagree with your points 3 and 4.
According to FAR 91.207 the manufacuterer determines when the battery will reach 50% of it's capacity while in storage. The battery is in storage from the time it's manufactured through the time it sits on the shelf and the time it sits in the ELT waiting for ELT activation. That date is the date marked on the battery.
Well, ... that's not exactly what they are saying. Unless para. (c) (2) can be verified, the annual inspection requirement of 91.207 establishes the chronological limit of installed batteries.N9149A wrote:We aren't talking Durocells here but the propriotary batteries I have in both my ELTs. These batteries can not be used after the replacement date regardless when I actually install them.
Some batteries I've bought I've been able to use for 23 months the last one I installed I'll get 25 months of usage.
There is no requirement by FAR 91.207 for anyone to inspect the battery for capacity annually.
According to my FSDO, the ELT mfr does not have authority to extend the shelf life of Duracells (different mfr's), and once installed, the clock begins. (Also once installed, if used more than 1 hour, or if less then 50% of their capacity remains (there's the question again)...they must be replaced, and unless they are tested (something we all have the capability to do, right?N9149A wrote:While I don't have an ELT which uses common commercial batteries such as Durocells since 91.207 gives the ELT manufacturer the authority under other approvals to determine when in storage the battery for their ELT reaches 50% of its capacity, the ELT manufacturer would specify any battery that can be used with their ELT and the relationship of the expertion date any date stamped on those batteries.
Not saying I agree with them....just repeating what they explained to me.
(By the way, ACK also states under their "battery replacement' section, that "Section 7" dictates periodic maintenance. Section 7 stipulates that the date of batteries must be checked every 12 months, and replaced in accordance with Section 1 (which re-iterates the 50% rule.) Do your batteries have 50% capacity?
I personally hold an opinion in disagreement with the FSDO, but wanted to let everyone know what I've been told directly by their avionics inspector. Duracells are cheap enough to replace annually, and the old batteries do good work in my flashlights. I wish the ELT's were as reliable as common flashlights.
![Confused :?](./images/smilies/icon_confused.gif)
