Axle Shims
Hal
Axle Shims
Post by Hal »
Does anyone know how to measure the shims to determine the part number for adjusting the toe in/out and the camber for the MLG of the C-170? Hal, 5568C
Here's a link that may help you. Keep in mind that the distance the shim displaces a 6:00 wheel at it's rim is the measurement they are discussing.
http://aircraftspruce.com/catalog/lgpages/tapershim.php
Hal
Axle Sims
Post by Hal »
Thanks Geo for the response to my shim question. I should be more specific as I have some shims in my tool box and would like to determine the P/N. Is there a way to measure the thickness at the thickest corner and/or the thinest corner to determine the P/N ?
That's an excellent question, and I don't have that data. I don't know if Cessna will part with it either, but one of the distributors might be willing to "mic" a few to let you know. Post the results if you get them!
You might be able to deduce the PN's if you have a sufficient number of shims.... They only made a few shims and obviously the one with the thickest corner will be the one with the most adjustment, the one with the thinnest measurements will have the least effect, etc etc.
53B
Axle Shims
Post by 53B »
Hal,
I had to buy shims for my 172 conversion. For some reason I thought it would be a good idea to measure them before I shimmed the axles. I didn't buy them new, but they all have what looks like the Cessna ink stamp part numbers so here is what I have:
0541111-2 .191 .148 .103 .060
0441139-5 .090 .079 .052 .039
0441139-6 .125 .105 .062 .041
Hope this helps!
Happy Flying,
Mark
1958 Cessna 172 N9153B
