Concord Batteries
Concord Batteries
I was browsing the Concord Battery web site for the specs on the RG25 batteries. Under the certification notes, they say, "Replaces Original p/n 0511319-1. Aircraft serial number 18730-20266 except 19401."
Who has SN 19401, and what is so special about your airplane that this battery doesn't work?
No Cessna 170 shows up with that serial # in the faa database at http://www.landings.com. 19400 (N9597A) and 19403 (N9713A) show up as 1950 A-models, but nothing in between.
![Confused :?](./images/smilies/icon_confused.gif)
I put one in my Citabria last year, and plan to do the same when the battery in the 170 craps out.Dave Clark wrote:I've had the RG-25 for three years now and it's great. No more worries about acid venting, no maintaining acid levels. Gotta love it
Craig Helm
Graham, TX (KRPH)
2000 RV-4
ex-owner 1956 Cessna 170B N3477D, now CF-DLR
Graham, TX (KRPH)
2000 RV-4
Battery
I just put one in my 170 and I have to say it was strange. The battery was charged with a trickel charger for 24 hours before installing.
I put it in the plane and it was dead the next day. I recharged the battery on the work bench that has a wood top. two days later it was dead again. I called the Mechanic that sold it to me that did the annual inspection he said put a trickel charger on it and leave it on. So thats what Im doing now. Just for fun I now take the trickel charger off and it takes about one week before the battery starts going down again. Never seen a battery do this before. Any ideas ? or just keep the charger on it.
Other than that, it looks to be a great battery, with no acid problems.
Bill
Bill
I don't know if these batteries can sulfate or not. If they do, you need to charge for about 1-2 hours at a very warm to touch battery. this breaks down the sulfate on the plates from storage.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
Re: Battery
If you've tested that not "hot-wired" items are drawing the battery down, it sounds as if you may have obtained a battery with an internal short/leak. (Don't forget about avionics that have "keep alive" circuitry, such as "last-frequency-used memory", older-type elect. clocks, etc., will draw a battery down but it takes a month or so with a healthy system.)Boiler Bill wrote:I just put one in my 170 and I have to say it was strange. The battery was charged with a trickel charger for 24 hours before installing.
Bill
Concord Battery
I ran a concord RG-25 in an Ercoupe for six years before replacing it. I put one in my 170A 3 years ago and it is running/performing great. I usualy take the battery out in Dec and put it in my shop hanger on a shelf and in Mar I put it back in the 170A. If one reads the Concord maintenance manual it tells you to NEVER put the RG-25 on a trickle charger because it will ruin it. When you receive the battery from your supplier you should NEVER put it on a charger! If you do you will blow it. Hal Singrey ![Very Happy :D](./images/smilies/icon_biggrin.gif)
I use the Concorde RG-25XC battery in my converted 172.
The Instructions for Continued Airworthiness have pretty clear instructions on how and when to charge the battery.
http://www.concordebattery.com/otherpdf/IFCA1.pdf
I also use these batteries in the Citations and King Airs in our charter operation with very good results. Virtually no maintenance costs after the initial purchase and no worries of corrosion issues on our aircraft.
Happy Flying,
Mark
1958 Cessna 172 N9153B
Mark
It looks like they don't like a constant current but what battery does? I'm probably wrong on this if so someone please correct me but it would appear a tapering charge type charger would be ok. After all that's what the aircraft voltage regulator does. As for the trickle charge if the voltage can't go over 14.1 volts and it's only a couple hundred milliamps it should be ok. When I use trickle chargers in long term storage situations I put them on a wall wart type timer and give them an hour or so per day.53B wrote:I use the Concorde RG-25XC battery in my converted 172.
N92CP ("Clark's Plane")
1953 C-180
1953 C-180
