rat patrol
iowa
rat patrol
Post by iowa »
what is the best method
to keep mice out of your 170's!!
i use the circular piece of tin
with the square of plywood
(to keep them from crawling up the tin's seam)
it seems to help
any other ideas?
iowa
1951 170A 1468D SN 20051
AME #17747
sphillips
Post by sphillips »
The guy I bought mine from hung little bags of moth balls on the landing gear legs just up hill from the axles, and on tailwheel spring.
N3598C, C170B
Iowa,
Your problem is that that hangar is WAAAAY too clean! You need to put some junk in there to give the mice a low-rent housing option to your 170. If you don't have any junk, I've got several truckloads you can have for shipping costs. :wink:
iowa
Post by iowa »
miles
this was taken just after the hangar was built!
now it have a decidedly different look!!
dave
AME #17747
thammer
Post by thammer »
Those are two of the biggest mice I've ever seen! They must be tough 'cause they're standing on their hind legs!!
tye
iowa
Post by iowa »
i'll have to tell my mice
after they wake up
(its 5am)
what you called them!!
dave
AME #17747
WWhunter
Post by WWhunter »
Those aren't mice!!! They're called..Rug Rats!! LOL
Never let anyone eat any food in your airplane! Never! Water in bottles only!
The slightest crumb will teach them that food is available in there, and they'll find it.
I guess a cat is out of the question?
iowa
Post by iowa »
george
the headliner and padding
is pretty enticing to a cold mouse
in a very cold hangar!!
dave
AME #17747
Kyle
Post by Kyle »
Those small little sticky pads available at the local hardware are great. Leave one just inside behind the pilots seat on the floor (that way you see it as soon as you open the door and don't fly around till it sticks itself to your interior. Place the other on the floor next to tailwheel. That's the one the usualy get's em :!:
Good Luck ....
Kyle T.
Kyle Takakjian
Truro, MA
52 C-170B, N8087A
Kyle I've never figured out how people could use those sticky traps. I'd rather set a good old snapping mouse trap and humanly quickly kill the mouse rather than have it starve to death.
My hanger partner has about 6 traps set in the hanger and uses peanut butter which lasts a while.
Not likely found around hangars, but ... Jamie loves to feed the birds. She has several birdfeeders around the place and they scatter the birdseed all over the ground and on the back-porch, etc.
It didn't occur to me for some time that it wasn't until that birdseed was all over the place that we began to see the occasional field mouse around the house. Then I began to notice snakes around the place.
I think I'm going to have to discuss the bird thing with her.
Fortunately I've not yet found any mouse evidence in the hangar even tho' it's at the end of the house. This discussion has me thinking that maybe I'd better remove the baggage bulkhead and take a look, just for good measure.
iowa
Post by iowa »
does the sticky thing work in cold weather?
iowa
AME #17747
jwmcgu
Post by jwmcgu »
Bruce, If you need to replace the headliner, you will not feel sorry for the little criters. I replaced mine this month. Kyle, I use the same location for the sticky pads and it works very well. One other point that has not been suggested, I've used the canned foam around the bottom of the hangar walls to prevent the initial entry (I hope).
John N2488D
jrenwick
Post by jrenwick »
In the hangar, there's always the bucket trap, which has several variations. Easy to make, low maintenance. Google for "bucket mouse trap" or start here for an example: http://www.kountrylife.com/content/gal1017.htm
John Renwick
Minneapolis, MN
'42 J-3 Cub, N62088
