0-300A Running problem on a rebuilt engine.
You can get the bore snake at military surplus, firearms supply stores. It looks like a piece of nylon rope, rather large diameter, with a smaller string on one end. You'll have to push some safety wire thru the fuel line then tie off to the string on the snake. When you pull the snake thru, it is specially woven to conform, with a fair amount of resistance, to the "bore".
I'm not sure if more than one size is available because the snake is designed for field use to work for a range of bore sizes. I'm certain it works on 3/8" fuel line
Del Lehmann
Mena, Arkansas
Mena, Arkansas
