HA wrote:it would have to be a lot of slop to flutter at the breakneck speeds these machines attain
but it will only get worse as it works and elongates more, so you should fix it
Scariest flight, bar none, that I ever had was on an old 65HP T-Craft. I had just taken off from Merrill Field in Anchorage headed south when all of a sudden, the control wheel started slamming in and out of the panel.
It was moving so hard that I could not control it and I had no idea what was going on. I tried to jam my arms in a way to stop it but I wasn't strong enough. I felt like a jack hammer was connected to the wheel.
I slowed up immediately just above the stall and it abated somewhat but I still could not stop the control wheel from bouncing in and out. There was a small field, O'Malley air strip, straight a head and I went in immediately, fully expecting the back end of the plane to snap off before I got there.
I landed, pulled over and got out, seriously considering taking up golf. I was that scared. After, more than 30 years, I am still embarrassed about that (the golf business, not being scared.)
The push rod to the elevator trim tab bad just broken off, fatigued. It had apparently caused flutter in the whole elevator. Very, very bad news indeed.
Fixing this is a good iead.
