oil leak
davevramp
oil leak
Post by davevramp »
I have an oil leak that is driving me nuts. Oil appears on the carburetor, the front left stud is wet. It does not leak unless the prop is spinning. My question is does the carburetor mounting studs go in to the oil side of the sump? It looks like a real mess taking all of that baffling off. My oil consumption is 3 hr to quart and most of that is o the belly of the aircraft. Any help would be appreciated
4583C
Post by 4583C »
I would Strongly recomend you check this out immediately as you may have an early warning of the infamous C-145/O-300
oil pan failure! The area in front of the induction tube which goes thru the oil pan is the area which traps moisture and sets up the corrosion. The studs are blind (they don't go thru the pan) Removing the baffling or pulling the engine is a pain but nowhere near as painful as spreading your engines oil over the countryside.
53B
Post by 53B »
Not sure about the studs going through the sump. We did have an Ercoupe in the shop last summer that leaked oil out of the carburetor. Turned out the intake guides were worn allowing oil to leak back into the induction pipes and out through the carburetor.
Hope this helps!
Happy Flying,
Mark
1958 Cessna 172 N9153B
Dave the sump is a concern but more that likely you have a leak from a push rod tube. Clean the engine really well then carefully run it and check.
Look around the rubbers at the base. Also the leak more commonly at the head end. I actually had several tubes with hole rotted in them when I rebuilt my engine.
Oil can get every where and can really be a pain to track down.
N2865C
Post by N2865C »
There is a good thread on finding leaks here....
http://cessna170.org/phpBB2/viewtopic.p ... 54&start=0
I find that the Magnaflux developer works well.
N2865C
IF it truly only leaks when the engine is running, ...wash the engine down and blow it dry. With the cowl off, run the engine 5 minutes and shut it down and watch it.
It could be from any of the sources mentioned already, or it could be a leaking prop-shaft seal, and running/blowing back.
It's also possible that a cylinder is leaking at it's base.
If it leaks only 5-10 minutes after shut down, then remove the induction from the suspect cylinders to see if it's wet inside and coming from worn valve guides. (This can be seen by loosening the induction hose clamps and sliding the hoses down the pipes to see if oil drips out. This method may save you a lot of unnecessary work locating which valve guide is leaking.) What sometimes happens is,...while the engine is running the valve guide has a vacuum on it due to the intake stroke....so the oil is burnt in the combustion chamber. But when the engine is resting the excess clearance between the valvestem and guide allows the oil in the rocker-box to drain down the valve stem/guide and run down into the intakes....and may eventually make it all the way to the carb. (But usually this becomes evident inside the air box and carb throat....not external to the carb.)
If you end up removing the baffling surrounding the sump.....use a 1/2" wooden dowel, rounded on the end, and by hand, attempt to "punch" a hole thru the floor of the sump about 2"-4" forward of the carb, in a pattern covering every half-inch of that entire area. Don't be gentle. If you can punch a hole thru the sump with a 1/2" wooden dowel by hand...then consider yourself lucky to have discovered it on the ground.
Tom Downey
Post by Tom Downey »
The studs for the carb mount do not go all the way thru the sump.
but corrosion will. and at first the oil can only go thru the hole when it is hot.....
Tom Downey A&P-IA
davevramp
found the leak
Post by davevramp »
After removing the paint in the area of the leak I now have a 2 to 3 oz leak a day.
Engine does not need to be running now to leak.
I am in need of a sump for a 145-2 and my sump has 5 bolts.
If any one knows of a good sump please let me know.
I hope you guys, that have responded to my questions, know how much and I value your comments.
This could have turned out a lot different.
Many thanks
doug8082a
Post by doug8082a »
When mine went I found a sump from an engine shop that recycles usable parts. I must have called 20 or 30 places and had 3 or 4 shipped to my mechanic before we found an acceptable one. I don't kow if you can still get these new or not. My used price 7 years ago was about $400 + shipping.
Try calling TCM and see if you can even get a new one any more. That will at least let you kow what you are up against availability-wise. In the mean time start calling places like Preferred Airparts, Dodson, Global Aircraft, Dawson, etc., etc. (these and many others can be found in Trade-a-Plane and other publiations or you can Google them on the web). When I was searching for the sump, if the place I called didn't have it I asked them for names/phones numbers of other places to try. Most everyone was willing to refer me to other shops, so don't be afraid to ask. It wasn't long before I had a large list of companies and phone numbers.
Have a good look at the inside of your sump when you get it off the engine. You'll be amazed at how much damage water can do just sitting there.
4583C
Post by 4583C »
El Reno Aviation in El Reno OK. 405-262-2387. They are very knowledgeable about our engines and nice folks.
4stripes
oil sump
Post by 4stripes »
When the oil pan starts to go watch out! It develops a large leak fast. I found one that had been overhauled by Drake. I believe that they may be one of the only companies that can fix and certify your old sump. I couldn't find a new one anywhere. Here is their web link
http://www.drakeair.com/
PS once your pan is off, Have a good look at your cam lobes... I had a slight flat spot on the lobe closest to the prop shaft and had to change the cam too.
Best wishes Eric
What is the name of the outfit up in Kelowna that does a certified repair to the sumps with epoxy?
4583C
Post by 4583C »
cessna170bdriver wrote:What is the name of the outfit up in Kelowna that does a certified repair to the sumps with epoxy?
Okanagen Aero Engines Discussion found here;
http://www.cessna170.org/phpBB2/viewtopic.php?t=3746
