Considering a 170 and loking for advise
- wa4jr
If I did not already have a '54 170B and you were to pass on that 53 170 project...I'd be hooking up my trailer ready to roll up to the door and save her! Timing is everything I guess. Sounds like you have a really good 170 foundation there that you can rebuild to your tastes a bit at a time. I like these project because I can rebuild to my personal specifications incorporating many new mods and I can spread the costs out over a couple of years vs. coming up with financing for a $34K ready to fly bird....and then here I am reworking all the avionics already! BUT....I could sell my '54 and be ready for that project! Hmmmm? Nope, I have already bonded with my '54.
Since I'm needing a post 53 cowling, how far into the 172's can I go?
I could live without that 2nd door in the cowling, but I'd sure hate too!
Actually my top half is in good shape, maybe I could just replace the lower half and maybe nose bowl with 172? I like this cowling. Pilot side door stays latched (on mine anyway), the other door has two screws in it, I change the oil (quick drain) & clean screen easily without pulling off cowl, also just changed the generator twice through the two doors - no problem, of course the oil cooling and other improvements I appreciate as well. Can I expand my cowling search from 53 up in to the early 172's. Maybe the 172 cowling's housing the 0-300's will fit 170's?
Most likely. The belt driven vacuum pump sits in the same plane (no pun intended
) as the front of the cowling, so an unmodified cowling would prohibit the installation of the pump. I've seen several where they have replaced the nose bowl with a '60's (I think) C172 nose bowl - the one with the single large oval opening that extends to either side of the prop. I even saw one on an "A" model where they just cut a hole in the front of the cowl to accomodate it, but it wasn't too attractive.
The '53-'56 cowling has an opening on either side of the prop shaped like an elongated "D" with a horizontal bar through the center where the upright part of the "D" is closest to the prop and the rounded part is nearest the outboard part of the cowl. The split occured along the same line (but just below) as the horizontal bar that divided the "D" shaped openings.
When the battery was on the right side and the oil filler on the the left (as always) there was a need for two doors. When the battery was relocated to the left side then the need for a door on the right was deleted.David Laseter wrote:Yes the 1960 model cowling that I looked at the other day, looked exactly like my 55, but without the 2nd cowl door. Why would they take that door away? There must be some reason. I would think that Cessna would continously try to improve their product.
(Wanted 53-60 Cowling)
