The time has come and 39A is at the avionics shop getting it's "new" radios installed. Shop says that they'll have to relocate both existing antennas
Any ideas???
Thanks!! Chris
Comant has no control over what year-model or type radio their antennas are connected to. They are relying upon "conventional wisdom" ...which works fine, even today. Their advice to refer to each mfr's guidelines is good.n2582d wrote:If is only a requirement from vacuum tube day it's interesting that Comant says the following in their FAQ:
How much distance should there be between antennas ?
You should maintain 36 inches as a minimum distance between antennas. Some antennas, such as SATCOM, may require more. Refer to each manufacturer's installation guidelines.
When it comes to interactions between various pieces of RF equipment, I've come to expect "wierd" as "normal". When my King KN64 DME is tuned to certain channels, my Narco 150TSO transponder replies to its interrogations. I know that DME and Transponder frequencies are close to each other, but I've never been able to establish a pattern as to which channels cause it and which ones don't. In any case it doesn't seem to cause any operational problems. (Yes, I know DME is only a couple of generations past airway light beacons, but until Santa drops me a 5-digit stocking gift, I'm gonna hang on to it.)hilltop170 wrote:Another weird solution for an odd problem to keep in your bag of tricks should that ever happen to you.
Miles, interference between DME and TXDR is common, expecially among older equipment. There is a "suppression" channel that interconnects your DME/TXDR that can be enabled. It's a simple coax connection between the two radios.cessna170bdriver wrote:When it comes to interactions between various pieces of RF equipment, I've come to expect "wierd" as "normal". When my King KN64 DME is tuned to certain channels, my Narco 150TSO transponder replies to its interrogations. I know that DME and Transponder frequencies are close to each other, but I've never been able to establish a pattern as to which channels cause it and which ones don't. In any case it doesn't seem to cause any operational problems. (Yes, I know DME is only a couple of generations past airway light beacons, but until Santa drops me a 5-digit stocking gift, I'm gonna hang on to it.)hilltop170 wrote:Another weird solution for an odd problem to keep in your bag of tricks should that ever happen to you.
Miles,cessna170bdriver wrote:When it comes to interactions between various pieces of RF equipment, I've come to expect "wierd" as "normal". When my King KN64 DME is tuned to certain channels, my Narco 150TSO transponder replies to its interrogations. I know that DME and Transponder frequencies are close to each other, but I've never been able to establish a pattern as to which channels cause it and which ones don't. In any case it doesn't seem to cause any operational problems. (Yes, I know DME is only a couple of generations past airway light beacons, but until Santa drops me a 5-digit stocking gift, I'm gonna hang on to it.)hilltop170 wrote:Another weird solution for an odd problem to keep in your bag of tricks should that ever happen to you.
Don't forget about Montgolfier and my skill with hot air!johneeb wrote:... Shortly a generation will look on our generation with awe at having been able to work with DME, similar to the way we look at Bllueldr's generation for their skill with a radio range.
I made that connection and it didn't work, although as I remember I made it with twisted pair, not coax. Not sure if the problem is on the DME or transponder end. ATC has no problem with the transponder, and I have no problem with the DME, so I just left it.gahorn wrote:Miles, interference between DME and TXDR is common, expecially among older equipment. There is a "suppression" channel that interconnects your DME/TXDR that can be enabled. It's a simple coax connection between the two radios.
It was standard practice until just recently for the channel to be enabled, but sometimes it's overlooked, expecially when the two pieces of equipment are installed at different times/by different shops.
A friend of mine recently retired as an instructor at the Air Force Test Pilot School, and now serves as "Chief Instructor" at the Edwards Aero Club. In the last month or so they took delivery of a new 172 with a G-1000 (the ONLY way you can get them these days). He says the SOP suggested by Cessna is to engage the autopilot above 500ft. If this keeps going, the new generations will be in awe that we once were able to manipulate aircraft controls.johneeb wrote:Miles,
Isn't it interesting how fast we become blase about the information that is available to us today. Until the advent of handheld GPS I used to be envious of anyone who had a DME. Shortly a generation will look on our generation with awe at having been able to work with DME, similar to the way we look at Bllueldr's generation for their skill with a radio range.![]()
I'm not sure if it was the HF or early VHF sets, but Dad talks about an old radio where you had to physically change crystals on the front of the radio to change channels. If a flight required multiple channels to be used, you kept the crystals on a string tied to the radio to keep track of them.blueldr wrote:After all, the civil aircraft all operated on HF and the standard frequency for an aircraft transmitter was 3105KC. Everyone was on that frequency. You listened on a tuneable receiver on frequencies from 200 to 500 KCs. A common tower frequency was 207.
