The point I hoped to make is that sometimes WARM engines will not start as easily as cold engines.
The assumption that a hot-mag test on a warm engine will prove out ... is not necessarily valid.
(And I've always assumed a prop is "hot"... but I clearly had a severe brain pharrt that day.)
When I was getting ready for the GLS convention, our fellow member and right-seater course instructor, Bob Lavery, was getting familiar with my airplane, one that ALWAYS starts easily hot or cold, never taking more than a blade or two to roar to life.
Bob had an injured right shoulder and suffered pain whenever he attempted a pull on the starter knob unless he used his left hand to assist his right. He would pull with both but he was being too gentle to overcome the strong spring-action of the clutch sufficiently to engage the starter button electrical contact. He was concerned he'd hurt my airplane if he yanked it too hard.
In the middle of our familiarization flight, we'd made a Coke-stop at Hamilton.
To our disgust the FBO was closed.
(Here's Bob panning for the camera, mimicing extreme disgust.)
So we decided to hop over to Stephenville for a Coke instead. I got back into the right seat, and Bob tried his gentle pull on the starter cable knob and ...again... he didn't pull it sufficiently hard to engage it so nothing happened.
I admonished him to "PULL --- You won't hurt it, Bob!"
He yanked as instructed.
The entire control cable came out of the panel and his double-handed fists struck me in the chest.
We both sat there immobile...... He, embarrassed (needlessly) that he'd broken my airplane. Me, breathless having had the wind knocked out of me.
We then both enjoyed a long chuckle over the event. It was a Laurel-and-Hardy moment.
I got out and I tried hand-propping the engine I knew to be an easy-starter. I absolutely wore myself out, and it wouldn't start. I was now embarrassed that it wouldn't start, and I was especially sensitive because I was afraid it was making Bob feel even worse about being the operator of the broken start-control cable.
I went back to hand-propping with even greather gusto. No deal. Not even a backfire.
Then Bob, very casually remarked to the so-called 170 maintenance expert... "George, isn't this broken cable normally connected to a lever on the engine?" (I didn't realize it at that moment, but He was doing what I've witnessed him do at his regular job at Simuflite teaching Hawker jets.... Bob is absolutely the best instructor I've ever known. He is so very good at what he does. He takes experienced jet pilots that have forgotten some detail they may or may not have ever completely assimilated... and when they've reached the extreme edge of their knowlegeability.... he asks them probing questions that lead to the correct conclusions in such a way... that they believe they have come upon the solution themselves! ... and that makes it such a memorable experience for them. It's embedded forever in their memories and they'll never forget it again! But Bob works his craft so well with the use of subtle, probing questions they are never in a position of embarrassment in front of their peers. What a fine talent he puts to good use!)
"Well, YEAH Bob! It just pulls a lever that operates a clutch-drive and then at the end of it's travel it operates the electric starter-motor to activate the starter-gear to spin the engine!" (What kind of dummy is he", I thought, "who would talk about such details which are so useless at a time when the control cable is broken and of absolutely NO USE! "Jeesh!"--- I thought.)
"Well", he continued, "... do you suppose you could see that lever through a cowl-door if the door were opened?"
I got it! The famous Cessna 170 "maintenance guru" GOT IT! (Thanks, Bob. You didn't have to make my dim-ness so obvious!)
I opened the cowl door, reached past the starter and pulled the lever. It started right up.
Conclusion: Just because an engine WON'T START is not a valid un-grounded magneto test. There are several reasons engines don't start besides magnetos. Warm engines can actually be more difficult to start than cool ones. Attempting to start a warm engine from a dead stop is not as good a "hot-mag" test as a switching mags off on an engine running at idle. Just a personal opinion that it's better to have the engine at low-idle and make the hot-mag test by momentarily switching both mags off, then immediately back on.
If the engine is accidentally allowed to die during a regular high-rpm run-up, then let it come to a complete stop, and make a normal re-start. Do not make the mistake of quickly switching it back on or you risk damaging counterweights and mufflers.
Hand-propping hint for dummies : One needn't hand-prop a 170 simply because a start-cable is broken. One can stay away from that prop over in front of the wing-strut where the cowl door is located.
