A little instrument panel clean out
learaviator
Post by learaviator »
I spent most of the weekend removing stuff left over from the last 58 years. Removed old radios and racks. Replaced every wire behind instrument panel with tefzel. Rewired mic and audio jacks, dome light, speaker, and all power wires to fuse holders. All new battery cables, mags and harnesses. Removed ADF antenna from belly. Found a flasher unit, about 4 inches square that I believe at one time was used to flash the nav lights. Found the stall warning buzzer/light mounted underneath the panel on the firewall. It of course does not work. All in all another productive weekend.
"You can only tie the record for flying low"
1950 170A N9907A 180hp. STOL
jon s blocker
Re: A little instrument panel clean out
Post by jon s blocker »
Don't toss that stall warning light and buzzer. They are easy to take apart and fix. look at your parts cat. and be careful while you take it apart. Look at earlier threads on the subject and look at the replacement costs! Just a thought as you go through the panel. Jon
Yes what ever you do don't through that stall warning horn/light away. I'll give you $5 and buy you lunch on my next visit to Havasu. :)
BTW the stall warning horn/light was an option on an A model and not a required piece of equipment.
learaviator
Thanks, I will look at it closer. I was thinking about replacing it with a buzzer, but I will rethink it.
B-model owners will find that the stall warning and light are REQUIRED equipment. And it's true...the price is scarey. Last time I checked, the horn/light was $2400 and the switch was $1600. 8O
Metal Master
Post by Metal Master »
I have that same wiring harness hanging on my wall in the garage. I keep thinking some originality nut might want to but it on e-bay.
Jim
