curiouse about an 0-320
i am not interested in putting one on because of a recent overhaul, but i see an STC for a conversion to put on a lycoming 0-320. does anyone have one, and if so do you like it?
i just couldn't help but think that since you get "almost the same" horse power out of an 0-320 but with a lot less weight that it would give you a boost.
thanks bill w.
thanks bill w.
Re: curiouse about an 0-320
Bill,
I don't have a 0-320 conversion and have only seen one. It was on a Canadian members plane. He was happy with it. Probably more because the constant speed prop allowed him to us all 160 HP available. Remember our 0-300 only develops 145 HP at 2700 rpm and there aren't many planes propped to achieve that rpm on takeoff.
The 0-320 was not a very popular conversion it seems because the 0-360 is the same physical size, is just as popular, and would be the same amount of work in the conversion. The only down side of the 0-360 over the 0-320 is they cost a bit more. As for the 0-320 conversion if I recall correctly it is for the 160hp version of the 0-320 with a constant speed prop. This version of this model engine isn't as plentiful as the 0-360 so if your going to do it your probably going to us the 0-360.
just wondering. i just recently overhauled my C-145-2 so no there will be no engine upgrades or changes for at least as long as i own the airplane. Mainly i was just wanting to hear someone brag about their bird if they did have this conversion.
thanks again
bill w.
thanks again
bill w.
Can we brag if we DON'T have it?
Just the other I spent the afternoon with a friend of mine assisting him with ground run ups and post maintenance checks on the Lear 65 he flies. I got a good look at the APU in the tail of the Lear and thought to myself - that would fit nicely on my C170.
Yes. And it would run on PURE MMO!
There is one on the airport here. The guy use to run it on floats but now the tires just go flat. When i was looking at buying it the performance was stated to be WAY better then a stock 170 and not as good as the 360. haha I never got a chance to fly it. It is not STCd but field approved.
here's a dumb question. what would you use for the engine mount, i.e. the guy who has the flat tire one?
bill w.
bill w.
- blueldr
I believe the engine mount for a lycoming O-360 would also fit an O-320. At least it would on certain models.
- 53B
mod cessna wrote:There is one on the airport here. The guy use to run it on floats but now the tires just go flat. When i was looking at buying it the performance was stated to be WAY better then a stock 170 and not as good as the 360. haha I never got a chance to fly it. It is not STCd but field approved.
mod cessna,
Would you happen to remember if that O-320 installation required cowl modification? Does it need the bumps on the corners like the O-360?
Happy Flying,
Mark
1958 Cessna 172 N9153B
Mark
- Jimmy M.
The 0-320 engine is narrower than the 0-360 by an inch or so, you shouldn't need cowl bumps.
Jim Martin
'46 Aeronca Chief, 160 hp ( homebuilt )
'56 170 square tail, 180 hp.
You guys are right there are no cowl bump outs. I had to go look first.
I saw an artical on a Cessna 170A/B with a Turbo Lyc O-320. It was cheaper to put in and had more HP at altitued. Less fuel burn and out performed the Lyc- O360.
WatkinsNV
The association's 170 Book has an article about this conversion written in the 1979-1980 time frame. does anyone know if this airplane is still around?
Bruce
Bruce
Bruce Shipp
