Fuel pump pressure
Kurt Aichele
Fuel pump pressure
Post by Kurt Aichele »
What, if anything, regulates the fuel pump pressure on the '48 ragwing? We just replaced the fuel pump with a rebuilt from Spruce. The fuel pressure is now above the green arc.
DWood
Re: Fuel pump pressure
Post by DWood »
I can't think of any control for the fuel pressure except for the pump itself. The check valve only controls the direction of flow. The next time I start mine, I will verify the pressure and advise on what I am getting. I replaced my pump about 2 years ago.
Dan
n3833v
Post by n3833v »
If I recall, my pressure runs between 4 & 5.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
Kurt Aichele wrote:What, if anything, regulates the fuel pump pressure on the '48 ragwing? We just replaced the fuel pump with a rebuilt from Spruce. The fuel pressure is now above the green arc.
Have you confirmed the calibration of your guage?
Kurt Aichele
Have not checked calibration yet. Also noticed there is a lot of needle flutter at engine idle, which I did not have with the old fuel pump.
DWood
Post by DWood »
I flew mine last night and the pressure is running around 5 psi. Of course the gauge was calibrated at the factory some 60 plus years ago or replaced and not entered in the logs. The interesting thing is that the green arc on the guage is 0 to 2 psi and the red line is 5.5 or so. I can't believe 0 would be in the green arc. As far as I remember the pressure has always been around 5 PSI and the only reason I replaced the pump is that I couldn't tighten the top half anymore to stop the leaks.
Dan
Kurt Aichele
Same thing with ours. Could not stop the leak, so we replaced it.
mrpibb
Post by mrpibb »
I run about 4 psi on mine, and the needle "flutters" at lower rpm ( mechanical diaphram pump), the perks of a 48, plus we get a extra gauge in our dashboard :) Mine was weeping a few years back, fixed by installing a new gasket kit from aero accessories, i dont know if they still have the kits, p/n is listed in the tcm SB m81-8r1. BTW my pump p/n specs out to 3.5 to 4.5 psi.
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
Kurt Aichele
Finally got back up in the air yesterday. Checked the fuel pressure gauge. Flutters between 3 and 6 psi at idle and between 4 and 6 psi at 2450 rpm with the new fuel pump. Seemed like the old fuel pump held a steady pressure at cruise power and fluttered at idle. Is this normal? Also, could this damage the gauge in the long run?
