Hello folks,
I'm trouble-shooting some electrical gremlins in my instrument lighting system and I'm looking for some info...
Currently, both my external nav lights and internal instrument lights (both the overhead "torpedos" and numerous post lights) are powered on by the same switch and run through the same fuse. They separate after the switch, with the instrument light circuit going on to the rheostat dimmer and the nav light circuit going it's own way...
In referencing my ancient parts catalog (printed in 1968), I believe I'm seeing that the wiring diagram for my '53 -B model should have them on separate circuits completely, with each having it's own switch and fuse, I believe 10-amp on the Navs and 15-amp on the instruments.
Which is correct?
Thank you,
-Kennet
Nav Light/Instrument Light switch(es)
- rydfly
1953 C170B - N170RP S/N 25865
Re: Nav Light/Instrument Light switch(es)
Neither. In all B-models the nav lites have their dedicated switch and 10A fuse. The instrument lighting rheostat obtains it's power from the 15A heater fuse (although very few airplanes actually had the Stewart-Warner heater) and the rheostat was the only control for the inst. lites.
- rydfly
Ahhhh... I see. Sounds like a re-wire is in my future. Thank you.
-Kennet
-Kennet
