I have looked through my Parts list on both the airframe and the engine; but, I can not find the part number for the "air box". Air box may not be the correct technical name; but, it is the device that holds the air filter and connects to the carburetor. I have a scanned diagram of the air box; but, I do not know how to put it in this post.
If anyone knows where I can obtain a new air box; then, please let me know.
Thanks for all of your help.
Remel
Cessna 170 B Air Box part number
- n2582d
Re: Cessna 170 B Air Box part number
Remel,
The carb heat box, p/n 530852, is available new from Univair for $700. If it's just your shaft that is worn take a look at McFarlane's repair kit FG-105. I see that this also works for airbox p/n 531143. Anybody know what the difference is between these two part numbers? To attach documents or pictures you've scanned click on the tab "upload attachments" which is located below the text you are writing. Then choose the file you have scanned. If it's a picture it should be a .jpg file; a .tiff file won't work. (It helps to find the picture if you have already renamed it something like "airbox.jpg" rather than looking for a number like 530852.jpg.) Third, click "add the file". You will now see the file name below the "File comment:" box in blue script. Often I'll make the remark "click to enlarge" in this comment box to clue guys into the fact that they don't have to look at a thumbnail size picture or text. Finally, place the cursor where you want the picture to appear in your text and then click "place inline".
Gary,
Thanks so much for all the information. Now all I have to do is figure out how to get $700.00. I was hoping that the part was not too expensive ($100-200 would have been nice). The problem is not a worn out shaft; but, the box got crushed so it is a lot on the deformed side. I might be able to use my hammers and dollies to see if I can straighten it out. The $700.00 price tag will certainly motivate me to see if I can repair the carb heat box. Thanks for giving me the correct technical name for the Carb heat box.
I'll look at the repair kit and see if that might be useful in restoring the carb heat box.
Thanks again for telling me how to store a picture in my post. The one I have is a .tiff; but, I can easily create the .jpeg images.
Remel
Remel
- n2582d
Remel,Cooper wrote:I was hoping that the part was not too expensive ($100-200 would have been nice).
Your wish is my command!
Did you happen to peruse our TradeMart section in case any Members (i.e. bluEldr) has one for sale?
http://www.cessna170.org/forums/viewtop ... f=7&t=6995
Thanks a lot. One of our Cessna 170 Association members has come up with an air box for me. I also bought a baggage door from him a few years ago.
Thanks for all of the help. I will examine the air box and consider installing the bearings you suggested.
- jrenwick
When you figure out how to install that bearing kit, please consider posting a tutorial with photographs of the process, and what tools you ended up needing. Thanks!Cooper wrote:...Thanks for all of the help. I will examine the air box and consider installing the bearings you suggested.
John Renwick
Minneapolis, MN
'42 J-3 Cub, N62088
Minneapolis, MN
'42 J-3 Cub, N62088
