Door Catch and Door Handle Latch repairs
- Joe Moilanen
- wa4jr
Uh-oh, this shopping trip for door latch/handle springs has me thinking of going the homebuilt route again so I can get my money's worth on parts. Hill Aircraft had the spring for the door handle....at $15 each, and the only outfit left in the country that has the latch spring is Avparts....at....are ya sittin down now....$25 each. Yes ladies and gentlemen, I paid $25 for each of two small pieces of spring steel
I see in the picture of the latch unit several posts up that someone had taken matters in hand and installed a standard coil tension spring...probably every bit of 50 cents. Instead of going back with AN470 rivets through the door skin into the latch end plate, I'll see if I can get a low-profile rivnut in there....so I will not have to drill out rivets again when my $25 spring breaks
- Indopilot
The spring thing has been discussed before where it mentions the 120/140 web site having plans for making a jig to one of the springs. After following the plans I decided it wasn't to hard to make that one so I adpted the plans and made a jig for the other one as well. For a dollar or so you can get enough piano wire to make lots of springs. For what its wotrh. Brian
52 170B s/n 20446
56 172 s/n 28162
Echo Weed eater, Jezebeel
56 172 s/n 28162
Don't lose sight of the overall picture. Does it make sense to get rid of a great 4-place airplane over a $25 spring that fails every 50 years, to buy a mediocre 2-place "modern" airplane that doesn't have the same abilities or appeal that will charge $25 for a door-hinge that fails regularly?
Keep a cool head about such things.
- wa4jr
The cloud has moved off and I'm OK now....that I sat down a couple of nights ago with some fine Port Wine
That sure is a nice latch assembly. The new springs are quite a bit heavier that the little fiddly things that go around the handle hinge pin as per original. I may just hold the original springs in stock and try to fit a pair of heavier coil tension springs. I can't see the spring that activates the latch, however. Is it in there somewhere? Is it the original. Since mine were gone, I have no idea how the new ones install and hope that it will be evindent when I have the shiny gold originals in my hand
- wa4jr
My springs have arrived, and it appears the door latch spring, #0411554 is of a new and improved design. I've never seen the original, but this new spring is not a single piece of flat spring steel. It is a dual coil spring similar to the one that goes on the handle, but much beefier. Somehow this new spring looks as if it is installed around the hinge pin on the latch cam, and puts a lot of outward force on the cam, thus insuring a positive door closure.
The picutures posted earlier have two coil springs that seem to pull the handle in while forcing the latch cam out...doing away with the dedicated latch cam spring. This would certainly work, for much less green, but I'll go ahead and install the factory parts and see what happens
- wa4jr
The job has been complete for some time now, but just now having time to write. The complete rebuild, cleaning, and new spring installation on the left door latch has worked wonders. Was a a bit difficult to install the new springs correctly, as the old ones were in pieces and the manual didn't say squat, but all worked out OK. I did make it a point NOT to rivet any of the latch assembly into the door. I used pan-head machine and steet metal screws so that when the springs decide to break again, I don't have to drill out rivets
- lowNslow
Mine were modified at some point by using rivnuts. They were installed in the two empty holes shown in the pictures below (where the rivets would go). Really made it easy to remove when I had to replace the springs.wa4jr wrote:I used pan-head machine and steet metal screws so that when the springs decide to break again, I don't have to drill out rivets
- mongo2
Re: Door Catch and Door Handle Latch repairs
I'm in the process of final re-assembly of my doors. Could someone post a picture of the door post and striker plate, as well as a picture of the door with the phenolic "half-moon" shown? I'm looking at the IPC , but I am slightly confused as to how the flat on the door latch is orientated to hold the door shut on the striker? I know the door latch can only be assembled in one position, but I'm having a hard time "seeing" this. My aircraft is far from where I am, so I have nothing to reference other than the door.
Any help appreciated,
Rick
Rick
Rick Champagne
C-170A N5475C
C-170A N5475C
I'm going to post some pics that may/may not be found helpful. The first set of pics is a modification to the original mouse-trap spring, using common hardware-store tension springs. Click on the pics to englarge them.
I do not think this mod will make your airplane unairworthy or cause it to fall out of the sky.
I'm confused too. Even looking at it and watching it work, it still seems backward, but works very well.mongo2 wrote:I'm in the process of final re-assembly of my doors. Could someone post a picture of the door post and striker plate, as well as a picture of the door with the phenolic "half-moon" shown? I'm looking at the IPC , but I am slightly confused as to how the flat on the door latch is orientated to hold the door shut on the striker? I know the door latch can only be assembled in one position, but I'm having a hard time "seeing" this. My aircraft is far from where I am, so I have nothing to reference other than the door.
Rick
- mongo2
Well ,now at least I don't feel as alone as not "seeing" how this latch works. It did seem to be backwards to me as well, thus the question. Thanks to you and George , I know I have things in place correctly. I took the the latch to the airport yesterday, and was able to see it work against the door jamb\striker. It does seem though that most latches would end up with the flat against the striker, but not in this case. I can now complete the riveting on the new door skin. I also changed my latch springs to the way George has his, and I installed rivnuts in the door jamb, and used nut plates on the latch. It is all completely removable.
Thanks again!
Thanks again!
Rick Champagne
C-170A N5475C
C-170A N5475C
Just to be accurate....those pics are not of mine. (I have original 172 rotary latches in my 170.)mongo2 wrote:.... I also changed my latch springs to the way George has his, ...
