Bearing Numbers
Bearing Numbers
Trying to find good numbers and vendors to get these bearings from.
Rudder SIK-5(Fafner)
Elevator AR-4-1(Torrington)Taken from bearing,could not find in part book.
Trim tab PN 3A
Any help appreciated
Trim tab PN 3A
Re: Bearing Numbers
Fafnir, was taken by Torrington, who now belongs to Timken. A W Bearings in Dallas handle all their products. http://www.bearingplace.com/manufacture ... ngton.html
The new S1K5 bearing number is Y120, but you don't want to buy it from Cessna!
I still have a new bearing a block for the rudder if you need one.
Re: Bearing Numbers
Thanks george
I went thru a outfit called LocateBallBearings.com(800-409-3632) They found all 3 bearings.Appox. $39.00 each. They could probably be found cheaper if you have the time. These people seemed very helpful. I will use them again if I have trouble finding bearings. Give them a try.
Re: Bearing Numbers
This would be a great opportunity to specifically list the bearing PNs and their superceded PN's and prices (according to that source.)mike roe wrote:Thanks george
Re: Bearing Numbers
I gave them all the numbers either in the book or off the bearing. From what I understood that is what they are sending. When I get them in hand I will add to this post.
Elevator trim tab- PN-3A
Elevator- AR4-1(Torrington)
Rudder- S-1K5(Fafnir)
Re: Bearing Numbers
Bearings showed up today.All part #s are the same as part book or off original bearings.
PN-3A(Fafnir) Trim actuator
SIK-5(Fafnir) Rudder
AR4-1(Torrington) Elevator
For hard to find bearing needs try this company.
Re: Bearing Numbers
LocateBallBearings.com(800-409-3632) ???
Re: Bearing Numbers
I was today quoted $732 ea from the Australian Cessna agent. I told him I wanted a price for one bearing not for a box of bearings! He went on to tell me what a good price it was given the strong Aus dollar.gahorn wrote:The new S1K5 bearing number is Y120, but you don't want to buy it from Cessna!
Work : AT502B
Play : '51C170A
Play : '51C170A
Re: Bearing Numbers
Oz, I think you might try a bearing company in the States, such as the one already mentioned in this thread, if your regs allow it.
This should be fair warning to others.... Inspect and regularly LUBRICATE those bearings with light oil.
Re: Bearing Numbers
How about the elevator trim end bearing??
