Just to add info to this thread for folks thinking about adding harnesses. Specially those of us with '51 and prior aircraft without the AN-3 nut plate already installed in the rear carry through spar for the purpose of installing a shoulder harness.
Wag Aero (
http://store.wagaero.com/product_info.p ... ts_id=2429) Wag sells a fixed harness for our aircraft for $169 a harness. With the harness comes their STC to drill the rear carry through and using their hardware, which is a few bushings, washers, a bolt and a plate. Unfortunately, in my eyes the installation procedure also calls for a hole in the upper skin above the spar in order to drop in the hardware and hold the nut for tightening. This hole is them filled with a rubber plug. I don't know but doubt if this procedure could be accomplished without the hole in the outer skin. I also am starting to think the holes probably aren't that big of a deal when one considers the added protection the harnesses can provide. I don't know if they would sell the STC separate for less but at $340 with the harness, the iron clad approval to drill the carry through spar for the attachment is probably worth it.
Hooker Harnesses (
http://www.hookerharness.com/aviationstckits.php.) Hooker sells a fixed harness and STC for our 170 at $225 (2009 price list) pr seat. Their web site says their installation does not require the hole in the top skin and uses a reinforcing bracket. They claim 1.5 hours to install with the headliner removed. Twice that with the headliner in place. Interesting to note. Hooker lists an inertia reel on their price list for $155. This is not part of their STC's package but I wonder if it couldn't be added.
The lack of harnesses in my 170A has been on the back of my mind for some time. I'd like to have them an have been trying to engineer a way to install the two I already have. I might do or call somethings minor alterations and do them that others wouldn't agree with. But I'd never make a modification under these circumstances that could not easily be undone. While there is lots of evidence drilling holes required for a harness in the rear carry through spar is OK, after all Cessna did it, it is not easily undone, and so I just won't jump in with a drill and do it, even to install something that could prevent injury.
Just yesterday a 172 made an emergency landing in Lancaster Pa. The plane hit nose first just making a runway. The pilot might have walked away with little injury had he not slammed his head into the instrument panel. Probably wasn't wearing the installed shoulder harness.
Think I'll be calling Hooker on Monday and inquiring about their STC.
(Well didn't take me long to find Spruce sells the Hooker Harness and STC for $197.)
